Although the documentation that came with my Toshiba SD-3750 standalone states that it supports CD-RW's, it will not load a VCD burned onto a CD-RW ("disc error: check disc"). The player plays VCD's on CD-R's with no problem.
Is this a media issue (I've tried both Imation and Memorex)? Or something else? Anyone else seen this? Toshiba support has not answered my queries.
Thanks.
CDRW's work just fine in my player. Just finished watching some simpsons episodes burnt on a CDRW. I used a Verbatim CDRW
I'm beginning to believe that this is indeed a media issue. I persisted with an Imation CD-RW test disk and, after a couple of tries, it finally played. Then, the next time, the error message again. I haven't tried Verbatim brand yet, so I'll look into that.
BTW, I read some of the reviews on this site for the SD-3750, and the problem reading CD-RW's seems to be a common occurrence. Seems as if it is just very picky about which brand it likes.
Thanks a lot.
Some silent DVD menus won't work on Toshiba Blu-ray player
By denali in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 7th Feb 2012, 07:04 -
pioneer dvr106d burns but won't mount dvds on my mac g5
By muscmp in forum MacReplies: 6Last Post: 27th Jun 2008, 23:15 -
Toshiba RD-XS35 won't play some disks
By inferno7 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th May 2008, 14:18 -
Toshiba DR2 Won't recognize DVD-RAM any more
By jpc82 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Dec 2007, 10:31 -
Toshiba Satellite Vista laptop won't recognize ram upgrade
By edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49
