I think I have finally found a solution to my problem. What video cutters can cut frame by frame in any point in time, reencode them to lossless formats, while keeping all subtitle tracks?
How do I batch burn in subtitles with clever FFmpeg GUI without manually having to save the same settings for each video?
https://forum.videohelp.com/threads/396490-clever-FFmpeg-GUI-a-lightweight-and-portabl...GUI-for-FFmpeg
Also, does SolveigMM Video Splitter offer lossless cutting?
Hi Jay,
the Splitter has two modes
1. frame accuracy smart rendering , where only a few frames are reencoded and the 99% of the rest is copied
[Attachment 79657 - Click to enlarge]
2. GOP or K Frame accurate mode. its 100% losless but has less accuracy
this is the how to use the splitter keeping subtitles
https://www.solveigmm.com/en/howto/how-to-edit-video-files-with-subtitles-with-video-splitter/Regards,
Dmitry | SolveigMM | Smart Video Editing (H624/MPEG-2/...)
Subtitle Edit - delete video and subtitle file after processing?
By svcds in forum SubtitleReplies: 0Last Post: 4th Jan 2024, 05:45 -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 12:28 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44 -
How to hide codes like <br/> />, etc. in subtitle file in subtitle edit?
By Pusat in forum SubtitleReplies: 0Last Post: 10th May 2023, 01:34 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52
