After doing all sort of tests, with both MPC-BE and PotPlayer, and all possible combinations of video decoders ( MPC, Built-in, LAV, etc ) and video renderers ( EVR, Direct3D 9 and 11, MadVR, MPC ) I *always* suffer from dropped frames in video playback if I have HAGS enabled ( Windows 11 23H2 Build 22631 ).
It's specially noticeable when using motion interpolation software like DmitriRender.
Video playback is ok when HAGS is disabled.
I would turn that crap off permanently, but you are FORCED to enable it if you want to use DLSS3 Frame Generation, like I need to do to be able to play Alan Wake 2 smoothly.
To enable or disable HAGS it says you need a full reboot of the computer, which makes this whole process a total pain in the ass...
So, any idea why HAGS makes dropped frames in video playback or how to solve it?
Is there any way to enable/disable HAGS without having to do a full reboot of the computer?
Any way to use DLSS 3 Frame Generation with HAGS disabled?
Any way to use DLSS 3 Frame Generation with HAGS disabled?users currently on my ignore list: deadrats, Stears555, marcorocchini
Fix video with dropped frames
By MartinBB in forum Newbie / General discussionsReplies: 7Last Post: 23rd Sep 2023, 04:55 -
Deleted
By KhAoS182 in forum Capturing and VCRReplies: 5Last Post: 22nd Sep 2022, 05:12 -
Dropped Frames?
By Craft in forum EditingReplies: 3Last Post: 13th Apr 2021, 11:05 -
How do you know the cause of dropped frames capturing VHS?
By bigbadben in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2020, 07:54 -
25fps with duplicates and dropped frames
By embis2003 in forum RestorationReplies: 6Last Post: 12th Oct 2020, 00:43
