I understand the large file made by Lagarith and always use it!
Have a few VFR mp4 files that display around 9fps in properties.
Plan to check with mediainfo for the max framerate.
Then choose a slightly higher framerate for CFR.
As I understand it just saving to AVI will force CFR output.
If I set the new CFR framerate higher then original VFR max, it might prevent any frame loss.
This will also allow me to save the clips to the same uniform framerate.
I am not worried about more duplicate frames!
Just wondering if there was a preferred method to maximize quality?
I have Adobe Premier and virtual dub.
What software or method will give a quality conversion with Lagarith save.
				Results 1 to 22 of 22
	Below ffmpeg commandline will reencode the clip to the new constant framerate and keep video and audio in sync. You can set the new framerate with fps=xx.
 I don't know whether ffmpeg supports lagarith as output, but if you need just a lossless output you could use ffv1:Code:ffmpeg -i "%~1" -c:a copy -c:v libx264 -crf 20 -vf "fps=30.0, format=yuv420p" "%~1_newFPS.mp4"
 Edit:Code:ffmpeg -i "%~1" -c:a copy -c:v ffv1 -vf "fps=30.0" "%~1_newFPS.avi"
 It seems ffmpeg reads lagarith files but has no codec option for outputting to lagarith. It supports many other lossless codecs like huffyuv, UTVideo .... and ffv1 (my preference). Why stick to lagarith?Last edited by Sharc; 11th Jan 2024 at 06:06.
	I have also used ffmpeg in the past to just convert to avi which forces cfr.
 ffmpeg -r 30000.0/1001.0 -i VFR.MP4 -c:v copy -an CFR.avi
 Trying to find a way to use Premiere or Virtualdub which have Lagarith.
 As you say, ffmpeg might be an option.
 When searching with Google I find site saying Premiere and Virtualdub can screw-up with VFR conversion.
 My guess was people trying to push their alternative product, so thought I would post a question here.Last edited by Tom4; 11th Jan 2024 at 09:58.
	I dont know how to get Lagarith going by using FFMpeg, but if Lagarith is an codec, you could download the codec separately and use an video converter that can function together with installed codecs, there are several completely free to use video converters capable of doing that!
 Edit: Especially if your an fan of lagarith, should defenitely download the codec, can use many free programs to get the best out of the codec for all scenarios with different input videos, formats and codecs! Funnily, once you get going there is allso the option to download other codecs that will function with such an converter aswell, even better is that the best codecs is free to use, most codecs allso will offer an separate settings application that can be launched from within the converter even tough the interface come along with the codec, possibly from here you can find many settings for quality, vfr/cbr, compression ratio, pixel output and so on, not all codecs offer such things tough and each codec offer different features within the settings!Last edited by Swedaniel; 11th Jan 2024 at 05:08.
	I'd just open it in VDub (I'd be using VDub2 64bit) and save it as a LAGS and see what happens. You'll be able to see the base frame rate under Video>Frame Rate.
 Be ready though for a huge AVI file. I just did a 60sec UHD VFR MP4 and it came out at 8.8GB! Constant FR at 30fps though. Nice.
 If it's HD or bigger, I'd be converting to CFR H264 to keep the file size manageable.
 They don't "have" LAGS, per se, LAGS is available to them because it was installed at some point beforehand.Trying to find a way to use Premiere or Virtualdub which have Lagarith.
	... and check whether video and audio (if there is audio at all) will stay adequately synchronized. Usually mobile clips are short though, so a minor deviation may not even be noticed.
 (but btw. why stick to lagarith?)
 Added:
 FWIW here another MediaInfo report of a mp4 clip. I don't know on what video (meta) data the report is based upon
 Frame rate mode : Variable
 Frame rate : 59.671 FPS
 Minimum frame rate : 39.805 FPS
 Maximum frame rate : 120.160 FPSLast edited by Sharc; 11th Jan 2024 at 08:30.
	I use lagarith because it is perfect every time without problems once you get the first RGB copy.
 Reprocessed the same clips over 10+ times and it retains all information.
 Most people ask why I use Lagarith to argue for their own choice.
 No idea why it bothers them. LOL
 Added: You see what I mean about using the max frame rate, so no frames are lost,
 the corrections can be made once I have a CFR version.
 If the maximum VFR for 9f/s video is above 30 I will settle for 30f/s.Last edited by Tom4; 11th Jan 2024 at 09:35.
	It seem pretty nice, i had been using Cinepak by Radius codec with the RGB24, which is pretty cool, now i see lagarith have that allso, plus ive got an hold of an YUV Viewer for YUV2 and YV12 but havent had much material to try it out, look like the Lagarith codec have some stuff to solve that problem allso!
 Edit: Well now ive tested the codec, it is working pretty good, colors looked a lil bit funny from over here with RGB, it worked better with RGBA, from within the codec settings there was options to enable multi threading, switch between RGB/RGBA/YUV2 and YV12, cant find any RGB24 tough! There was allso some other settings (Enable Null Frames, Prevent Upsampling When Decoding).
 Time to ship the material into some MP4, WebM, DivX, XviD, H.264, VP8 using various video converters to see how it goes, probably will test the Lagarith encoded material with WinRar and PeaZip to see how the compressions goes, since the videos take quite a bit of space!
 Edit2: Look like it was YUY2 and not YUV2! Plus the funny looking colors with the RGB was with VLC Media Player, when using NVIDIA 3D Vision Video Player + LAV Filters it is looking real good with the RGB videos allso!Last edited by Swedaniel; 11th Jan 2024 at 11:47.
	Neil from Adobe Community wrote on Nov 29, 2023 -
 Handbrake has a little 'radio' button you need to click called 'CFR' ... AND ... you also need to set a specific number framerate in the framerate option. Then it converts.
 ShutterEncoder can also convert, but for some reason they've moved the convert to CFR option from the general settings to the Preferences for the app. So you need to find those, there's an icon sort of thingie upper left of the UI that is their Prefs. Then find the option to convert to CFR, which takes some scrollling.
	That's not Sharc, for sureMost people ask why I use Lagarith to argue for their own choice.
	I found Sometimes the MetaData screws up the Video/Properties/Detail information through windows or software.
 Stripped MetaData and MediaInfo changed from "Fixed f/s" to "Variable f/s showing Minimum and Max f/s"
 After stripping the Metadata, I had a "Maximum f/s" or "Original f/s" for the script below.PHP Code:ffmpeg -i VID-IN.mp4 -map_metadata -1 -c:v copy -c:a copy VID-OUT.mp4
 Script below seems to work as intended, despite the -vf is repeated warning. I'm not good with this code!
 Remove Duplicate Frames - VFR 2 CFR - save as FFV1 RGB 16bit AVI
 PHP Code:ffmpeg -i VID-IN.mp4 -vf mpdecimate -fps_mode vfr -vf scale=in_range=limited:out_range=full
 -color_range 2 -c:a copy -c:v ffv1 -pix_fmt gbrp16le -vf "fps=29.970" VID-OUT.avi
 Anybody know the RGB type pixel/bit formats that are compatible with above code.
 I tried a dozen and only got "gbrp16le 16 bit" and "bgr0 8 bit" to work?
 There are also yuv type, if anyone can build on this.Last edited by Tom4; 13th Jan 2024 at 03:03.
	call:Anybody know the RGB type pixel/bit formats that are compatible with above code.
 to get something like:Code:ffmpeg -h encoder=ffv1
 and you see the 'Supported pixel formats'Code:ffmpeg version N-113317-g02fb3a775e-gbfa1b7577d+2 Copyright (c) 2000-2024 the FFmpeg developers built with gcc 13.2.0 (Rev3, Built by MSYS2 project) configuration: --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-doc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads libavutil 58. 36.101 / 58. 36.101 libavcodec 60. 37.100 / 60. 37.100 libavformat 60. 20.100 / 60. 20.100 libavdevice 60. 4.100 / 60. 4.100 libavfilter 9. 17.100 / 9. 17.100 libswscale 7. 6.100 / 7. 6.100 libswresample 4. 13.100 / 4. 13.100 libpostproc 57. 4.100 / 57. 4.100 Encoder ffv1 [FFmpeg video codec #1]: General capabilities: dr1 delay threads Threading capabilities: slice Supported pixel formats: yuv420p yuva420p yuva422p yuv444p yuva444p yuv440p yuv422p yuv411p yuv410p bgr0 bgra yuv420p16le yuv422p16le yuv444p16le yuv444p9le yuv422p9le yuv420p9le yuv420p10le yuv422p10le yuv444p10le yuv420p12le yuv422p12le yuv444p12le yuva444p16le yuva422p16le yuva420p16le yuva444p12le yuva422p12le yuva444p10le yuva422p10le yuva420p10le yuva444p9le yuva422p9le yuva420p9le gray16le gray gbrp9le gbrp10le gbrp12le gbrp14le gbrap14le gbrap10le gbrap12le ya8 gray10le gray12le gray14le gbrp16le rgb48le gbrap16le rgba64le gray9le yuv420p14le yuv422p14le yuv444p14le yuv440p10le yuv440p12le ffv1 encoder AVOptions: -slicecrc <boolean> E..V....... Protect slices with CRCs (default auto) -coder <int> E..V....... Coder type (from -2 to 2) (default rice) rice 0 E..V....... Golomb rice range_def -2 E..V....... Range with default table range_tab 2 E..V....... Range with custom table ac 1 E..V....... Range with custom table (the ac option exists for compatibility and is deprecated) -context <int> E..V....... Context model (from 0 to 1) (default 0)
 Are you sure the first two vf sections get processed and do not just get ignored?Script bellow seems to work as intended, despite the -vf is repeated warning. I'm not good with this code!
 (You could check with '-loglevel debug' to see what's happening,..)
 Better combing:
 toCode:-vf mpdecimate -vf scale=in_range=limited:out_range=full -vf "fps=29.970" Cu SelurCode:-vf "mpdecimate,scale=in_range=limited:out_range=full,fps=29.97" users currently on my ignore list: deadrats, Stears555, marcorocchini
	That would make sense, that the code was being ignored.
 So I need to fix it up and try again.
 Thanks for the help.
 I see the bundling, combing? of code using brackets but could not get it to work.
 I note there is no gaps with comma, have not got access to the PC to try this.
 So can I keep combing/adding commands in a string?
 Guess I will work it out.
 PHP Code:-vf "mpdecimate,scale=in_range=limited:out_range=full,fps=29.97"
 -fps_mode vfr -color_range 2 -c:a copy -c:v ffv1 -pix_fmt gbrp16le
	I was trying these,
 Available pixel formats are:
 Found that,PHP Code:monob, rgb555be, rgb555le, rgb565be, rgb565le, rgb24, bgr24, 0rgb,
 bgr0, 0bgr, rgb0, bgr48be, uyvy422, yuva444p, yuva444p16le, yuv444p,
 yuv422p16, yuv422p10, yuv444p10, yuv420p, nv12, yuyv422, gray
 bgr48be Auto selected to gbrp16le
 rgb24 Auto selected to bgr0
 bgr24 Auto selected to bgr0
 bgr16, rgb10 and rgb16 where unknown, along with a long list of others.
 There must be other factors at play for compatibility.
 Perhaps try:PHP Code:gbrp9le gbrp10le gbrp12le gbrp14le gbrp16le
	Yes, something like:
 works fine here.Code:ffmpeg -i "test.avi" -vf "mpdecimate,scale=in_range=limited:out_range=full,fps=29.97" -fps_mode vfr -color_range 2 -c:a copy -c:v ffv1 -pix_fmt gbrp16le "test.mkv"
 Regarding the pixel formats: seems like the ffmpeg authors might want to update their documentation.
 I normally use yuv color spaces:
 since my sources usually are yuv and adding additional color conversions doesn't seem necessary.Code:-pix_fmt yuv420p -pix_fmt yuv420p10le -pix_fmt yuv420p16le -pix_fmt yuv422p -pix_fmt yuv422p10le -pix_fmt yuv422p16le -pix_fmt yuv444p -pix_fmt yuv444p10le -pix_fmt yuv444p16le
 Cu SelurLast edited by Selur; 13th Jan 2024 at 04:03. users currently on my ignore list: deadrats, Stears555, marcorocchini
	Thank you very much for that, the video info was reading correct after process but I was concerned about cmd warning.
 Strip Metadata:
 For others trying this, its for "Variable Frame Rate MP4", removing repeated frames and saved to "Fixed Frame Rate Lossless AVI".PHP Code:ffmpeg -i VID-IN.mp4 -map_metadata -1 -c:v copy -c:a copy VID-OUT.mp4
 The idea was to create a clean CFR slate for processing.PHP Code:ffmpeg -i "test.mp4" -vf "mpdecimate,scale=in_range=limited:out_range=full,fps=29.97"
 -fps_mode vfr -color_range 2 -c:a copy -c:v ffv1 -pix_fmt gbrp16le "test.avi"
 Saving to "Variable Frame Rate MP4" can sometimes have advantage of reducing process requirements.Last edited by Tom4; 13th Jan 2024 at 04:46.
	Note that: This isn't a prefect approach: Code:mpdecimate,scale=in_range=limited:out_range=full,fps=29.97 - mpdecimate (https://ffmpeg.org/ffmpeg-all.html#mpdecimate) will remove all duplicates
- fps=29.97 (https://ffmpeg.org/ffmpeg-all.html#fps-1) will add back duplicates to archive 29.97 fps, so if after removing duplicates you get less frames (hopefully only in some sections) than are needed for 29.97 fps duplicates will be added back.
 Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
	I copied the sections to pad for reading.
 I think that mpdecimate removing all duplicates might be ok, provided they were close duplicates, because they will be replaced.
 If I can dig into the fps thing, are you saying the choice of 29.97 will add frames compared to 30? Thanks
 I used 29.97 because it was the original fps of a clip I was editing, will check this!
 So
 "fps=ntsc", "fps=30" or "fps=30000/1001" are the same and valid? Got it
 Reading the mpdecimate page again
 hi
 lo
 frac
 I will trying understanding this later.
 Thanks.Last edited by Tom4; 13th Jan 2024 at 05:48.
	Whether fps=XY adds or removes frames depend on how many frames you end up after the decimation.
 'fps' will add and remove frames to archive the given frame rate.
 '30000/1001' and 'ntsc' are the same.Code:"fps=ntsc", "fps=30" or fps=30000/1001 are the same and valid?
 30 and 30000/1001(~29.97) are not the same
 see: https://www.ffmpeg.org/ffmpeg-all.html#fps-1
	I read the stuff on "hi", "lo", "frac" functions.
 Crunched some numbers and ran tests.
 Seems to be in the right ball park, let me know!
 Higher resolutions might need the higher numbers.
 4744 Frames in Source Video (960x544).
 VFR to VFR mpdecimate test:
 4356 Frames "mpdecimate=hi=64*0.1:lo=64*0.1:frac=0.1:max=0" 8.17% of frames removed.
 4356 Frames "mpdecimate=hi=64*0.1:lo=64*0.04:frac=0.1:max=0" 8.17% of frames removed.
 4355 Frames "mpdecimate=hi=64*0.2:lo=64*0.08:frac=0.1:max=0"
 4354 Frames "mpdecimate=hi=64*0.4:lo=64*0.16:frac=0.1:max=0"
 4352 Frames "mpdecimate=hi=64*0.6:lo=64*0.24:frac=0.1:max=0"
 4351 Frames "mpdecimate=hi=64*0.8:lo=64*0.32:frac=0.1:max=0" 8.28% of frames removed.
 4338 Frames "mpdecimate=hi=64*0.9:lo=64*0.375:frac=0.1:max=0" 8.56% of frames removed.
 4312 Frames "mpdecimate=hi=64*1.0:lo=64*0.416:frac=0.1:max=0" 9.1% of frames removed.
 3830 Frames "mpdecimate=hi=64*12:lo=64*5.0:frac=0.33:max=0" 20% of frames removed. (Using mpdecimate Defaults).
 By setting "hi", "lo" and "frac" all to "0.1", it appears adjustment can be isolated to "hi" setting "0.1 to 1.0".PHP Code:ffmpeg -i VID-IN.mp4 -vf
 "mpdecimate=hi=64*0.1:lo=64*0.1:frac=0.1:max=0" -fps_mode vfr VID-OUT.mp4
 If you have experience with mpdecimate settings, please contribute.Last edited by Tom4; 14th Jan 2024 at 05:44.
  H264: VFR to CFR without re-encoding - possible?By rgr in forum Video ConversionReplies: 7Last Post: 11th Nov 2023, 12:32
  ffmpeg VFR to CFR in stream copy is possible?By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2021, 17:13
  VFR vs CFRBy rblu in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2021, 15:29
  VFR to CFR conversion before editingBy droner in forum EditingReplies: 42Last Post: 15th Feb 2021, 05:01
  VFR to CFR and Audio SyncBy videohelpuser in forum Video ConversionReplies: 3Last Post: 23rd Dec 2019, 11:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
