I'm about to get a Blu-Ray double disc "rip" (at least is what I think it is) from the "internet". I've always been able to play .mkv files, but this one is a different format: it's a whole bunch of directories containing ".clpi" files , ".mpls" files, ".m2ts" files (these way bigger in size), and a bunch of "cmap" files.
Since it's 2 discs, it sums up to between 80 and 85 GB's (huge). I'm getting from a private tracker, so it will take a big hit on my ratio. Because of that, I need to be absolutely sure I'll be able to play the thing before I get it. Does VLC open the directories (folders) normally? Do I need some other video player? Or will I need to convert it somehow before I play it?
Any help would be appreciated. Thanks in advance![]()
Closed Thread
VLC Media Player have an function "Open Folder" which should be able to handle an Blu-Ray folder structure! (Click on "Media" then "Open Folder", which will let you browse for and select an folder, locate and select the Blu-Ray folder here).
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
NON "English friendly" Blu-ray disc question.
By 2-perf in forum Authoring (Blu-ray)Replies: 10Last Post: 1st Dec 2023, 01:04 -
getwvkeys.cc code":400,"error":true,"message":"Failed to get license: 405
By Koldunas in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2023, 02:44 -
Can't play "wreck it ralph" blu ray in panasonic DMP BD605
By videdit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Sep 2021, 00:40 -
How To Better "The Bad News Bears{1976}" Blu-ray Video
By LouieChuckyMerry in forum RestorationReplies: 12Last Post: 31st Aug 2021, 13:42
