i use 'yuu' to download and it's error
i'm already add username and password (premium) and change the vpn
but i don't know how to fix itCode:C:\>yuu download -U *************** -P *************** https://abema.tv/channels*************** -r 1080p [INFO] Starting yuu v1.2.4... [INFO] AbemaTV: Authenticating [INFO] AbemaTV: AbemaTV: Fetching temporary token [INFO] AbemaTV: Parsing url [INFO][DOWN] AbemaTV: Starting downloader... [INFO][DOWN] AbemaTV: Total files that will be downloaded: 1 [INFO][DOWN] AbemaTV: Parsing m3u8 and fetching video key for files no 1 [INFO][DOWN] AbemaTV: Output: *************** (AbemaTV 1080p).ts [INFO][DOWN] AbemaTV: Resolution: 1080p [INFO][DOWN] AbemaTV: Estimated file size: 1224.68 MiB Downloading: 0%| | 0/175 [00:00<?, ?file/s] Traceback (most recent call last): File "c:\program files\python39\lib\runpy.py", line 197, in _run_module_as_main return _run_code(code, main_globals, None, File "c:\program files\python39\lib\runpy.py", line 87, in _run_code exec(code, run_globals) File "C:\Users\ACER\AppData\Roaming\Python\Python39\Scripts\yuu.exe\__main__.py", line 7, in <module> File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\yuu\command.py", line 204, in main_downloader dl_list = yuuDownloader.download_chunk(files, key, iv) File "C:\Users\ACER\AppData\Roaming\Python\Python39\site-packages\yuu\ext\abematv.py", line 68, in download_chunk with open(outputtemp, 'wb') as outf: OSError: [Errno 22] Invalid argument: 'C:\\Users\\ACER\\AppData\\Local\\yuu_data\\tmpqlbzgpa_\\D1Uibv39t85ciVgZ7TGnAFc3tgFTWiGyc.ts?aver=8x7jGM3LpkFJ3h'
and i try to use stramlink but i don't know how to add the username and password
anyone know the way to fix it?
sorry for my english
thank you so much
Results 1 to 21 of 21
The path is not valid, it should only have one backwards slash after each folder not 2, so C:\Users\ACER\AppData\...... not C:\\Users\\ACER\\AppData\\OSError: [Errno 22] Invalid argument: 'C:\\Users\\ACER\\AppData\\Local\\yuu_data\\tmpqlb zgpa_ \\D1Uibv39t85ciVgZ7TGnAFc3tgFTWiGyc.ts?aver=8x7jGM 3LpkFJ3h'
No idea,never used yuu. Can you try streamlink? Seems it supports the url you have.
Try
https://github.com/streamlink/streamlink/blob/master/src/streamlink/plugins/abematv.pystreamlink --abematv-username (username here) --abematv-password (password here) "url" best output.mp4 -
still doesn't work
Code:C:\>streamlink --abematv-username ******* --abematv-password ****** "https://abema.tv/channels/***" best output.mp4 usage: streamlink [OPTIONS] <URL> [STREAM] streamlink: error: unrecognized arguments: --abematv-username --abematv-password ***** https://abema.tv/channels/*** best output.mp4
it's still error
without VPN
with vpnCode:C:\>yt-dlp -u **** -p **** -f 5300 https://abema.tv/channels/******** [AbemaTV] Fetching media token [AbemaTV] Extracting URL: https://abema.tv/channels/************ [AbemaTV] 91SR94HwsHjfiF: Downloading webpage [AbemaTV] 91SR94HwsHjfiF: Checking playability WARNING: [AbemaTV] This is a premium-only stream [AbemaTV] 91SR94HwsHjfiF: Downloading m3u8 information ERROR: [AbemaTV] 91SR94HwsHjfiF: Failed to download m3u8 information: HTTP Error 403: Forbidden (caused by <HTTPError 403: Forbidden>); please report this issue on https://github.com/yt-dlp/yt-dlp/issues?q= , filling out the appropriate issue template. Confirm you are on the latest version using yt-dlp -U
i'm very sad ;w;Code:C:\>yt-dlp -u ************ -p ************ -f 5300 https://abema.tv/channels/************ [AbemaTV] Fetching media token [AbemaTV] Extracting URL: https://abema.tv/channels/************ [AbemaTV] 91SR94HwsHjfiF: Downloading webpage [AbemaTV] 91SR94HwsHjfiF: Checking playability WARNING: [AbemaTV] This is a premium-only stream [AbemaTV] 91SR94HwsHjfiF: Downloading m3u8 information WARNING: Extractor failed to obtain "title". Creating a generic title instead [info] 91SR94HwsHjfiF: Downloading 1 format(s): 5300 [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 175 [download] Destination: AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4 [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (1/3)... [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (2/3)... [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (3/3)... ERROR: Unable to download video: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'
(my id is already premium) -
i try to use playlist.m3u8 link
and it's still error
or i must do something with the link? ;w;Code:ERROR: Unable to download video: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl' 'ccf' is not recognized as an internal or external command, operable program or batch file. 'dt' is not recognized as an internal or external command, operable program or batch file. 'enc' is not recognized as an internal or external command, operable program or batch file. 'kg' is not recognized as an internal or external command, operable program or batch file.
when you get error like:
it's because you don't put m3u8 link (or video link too) into double quote "" so yt-dlp can't recognize full linkCode:'dt' is not recognized as an internal or external command
so, try with:
Code:yt-dlp --username xxx --password xxx "https://m3u8_link"
still can't download
code i use without vpn :
result:Code:yt-dlp -u *** -p *** -f 5300 "normal video url"
( i already use the latest verCode:WARNING: [AbemaTV] This is a premium-only stream [AbemaTV] 91SR94HwsHjfiF: Downloading m3u8 information ERROR: [AbemaTV] 91SR94HwsHjfiF: Failed to download m3u8 information: HTTP Error 403: Forbidden (caused by <HTTPError 403: Forbidden>); please report this issue on https://github.com/yt-dlp/yt-dlp/issues?q= , filling out the appropriate issue template. Confirm you are on the latest version using yt-dlp -U
result:Code:yt-dlp -u *** -p *** -f 5300 "playlist.m3u8 url"
code i use with vpn :Code:[info] playlist: Downloading 1 format(s): 5300 [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 175 [download] Destination: playlist [playlist].mp4 [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (1/3)... [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (2/3)... [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (3/3)... ERROR: Unable to download video: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'
Code:[info] 91SR94HwsHjfiF: Downloading 1 format(s): 5300 [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 175 [download] Destination: AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4 [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (1/3)... [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (2/3)... [download] Unable to open file: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'. Retrying (3/3)... ERROR: Unable to download video: [Errno 13] Permission denied: 'AbemaTV video #91SR94HwsHjfiF [91SR94HwsHjfiF].mp4.ytdl'
result:Code:yt-dlp -u *** -p **** -f 5300 "playlist.m3u8 url"
i don't sure because it's "playlist.m3u8" or something?Code:[generic] playlist: Downloading webpage [generic] playlist: Downloading m3u8 information [generic] playlist: Checking m3u8 live status [info] playlist: Downloading 1 format(s): 5300 [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 175 [download] Destination: playlist [playlist].mp4 [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (1/3)... [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (2/3)... [download] Unable to open file: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'. Retrying (3/3)... ERROR: Unable to download video: [Errno 13] Permission denied: 'playlist [playlist].mp4.ytdl'
i try to delete the "-f 5300" too but it's still not work :'(
or because it's the premium vid? but my id is premium account (i already paid for it ;w
if you can play this video without VPN, no need test with or without VPN
isn't VPN your problem
i think abema (not tested) use some protection and m3u8 link only isn't enough for download
anyway easy way: if you can play, use Stream Recorder extension or also Tubedigger to rip your video
or open new issue to github yt-dlp section -
Have you tried using "--cookies-from-browser firefox" (supposing you use Firefox) instead of "-u" and "-p"? Also try The Stream Detector browser extension to grab the playlist url in yt-dlp format (meaning it will add additional info and headers to your command).
Stream Recorder work but can't download in hq (the website don't have quality change button - -)
Tubedigger is work for me but it isn't full vid
it's have any software is free and work same as Tubedigger?
cause it's must login before watch the video
i'm already use extention to grab playlist url but it's still not work ;w; -
the difficult point is the decryption AES-128 key, still no one give an easy method to get the encrypt AES-128 key.(abematv-license://XXXXXXXXXXXXXXXXXXXXXX",IV=0x0xxxxxx)
I found a way to convert abematv-license:// to the genuine key.
Examples:
URL: https://abema.tv/video/episode/19-171_s1_p25
Screenshot:
[Attachment 77390 - Click to enlarge]
URL: https://abema.tv/video/episode/19-5_s0_p1
Screenshot:
[Attachment 77391 - Click to enlarge]
Till now free anime series are OK. But I haven't figured out those premium ones, since those need account & password -> token in some form
HELP! For download from ABEMA
By risemiamia in forum Video Streaming DownloadingReplies: 7Last Post: 18th Oct 2023, 03:25 -
Download from abema tv
By Sherazzie in forum Video Streaming DownloadingReplies: 23Last Post: 5th May 2023, 14:01 -
A GUI to download bulk download files through their respective M3U8 links
By UNforces885 in forum Video Streaming DownloadingReplies: 4Last Post: 4th May 2023, 15:04 -
Download HLS. error 400 to download keys
By naturalc in forum Video Streaming DownloadingReplies: 28Last Post: 28th Oct 2022, 09:13 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 22:28
