When I click on Destination Path, and I select the D drive (labelled "d: []") which I believe to be my burner, multiAVCHD gives me a pop-up box that reads "I/O error 1.". I click OK, and the destination path stays on the C drive.
What do I have to do to get multiAVCHD to burn a disc??
I'm using:
BD-R 6x/25GB disc
Asus BW-16D1X-U Blu-ray burner
multiAVCHD v4.1 (build 771)
I've got ImgBurn 2.5.8.0 installed
My computer:
2014 iMac
4GHz Intel Core i7
32GB 1600 MHz DDR3
AMD Radeon R9 M295X 4096 MB
Bootcamp running Windows 10
Don't use multiavchd to get imgburn to burn your folder,use imgburn directly and burn the folder.
Destination path is the location you want your created files/folders stored before burning. This must be a physical drive, not an optical drive.
The first time you check the Use Imageburn... box under Settings, you will need to select the location of the Imageburn executable. Also, ensure Imageburn is set up to recognize your desired optical drive.Last edited by Secoast; 9th Jan 2024 at 06:18.
Just need a little bit of info to burn an interactive blu-ray and / or DVD
By zakarns in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2021, 07:29 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 12:02 -
Best option to author .ass or .ssa subtitles to blu-ray with MultiAVCHD
By Bass_Soul in forum SubtitleReplies: 2Last Post: 3rd Apr 2020, 23:51 -
Noob: ANyway I can archive TIVO Roamio HD recordings to blu ray disc
By peggypwr1 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Apr 2020, 21:25 -
Burning 1080p & 720p H264 To Blu Ray Using MultiAVCHD
By citycentrefox in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2019, 19:49
