I have been encoding Blu-Rays for years and VC-1 is not something I come across very much.
Last time I came across it quite a while back, I was simply able to update ffms to a more recent version and it worked. Or at least it worked well enough and I did not notice any problems at the time.
This time however, I cannot get this to work properly. It file indexes and loads into MeGui, and seems to be working fine, but I am noticing small bits of corruptions and or blocks that were not there before encoding. Even using a more recent version does not fix this like last time.
The .m2ts/remuxed mkv plays perfectly in my media players, those blocks are not there. I want to encode it with avisynth though.
I tried using something called DGDecodeNV for the first time and the preview no longer shows those blocks, but the problem is, I cant get the script to work or load properly. Every time I try to load the script in, I get an error that's either a bunch of crazy symbols like this in AvsPmod.
or I get this error from MeGui
I can get this to encode with ffms2, but I cant get it to encode without these blocks and artifacts that don't belong there. When using the DGDecodeNV which looks like it works fine in the preview window, I cant get MeGui or AvsPmod to load the script or let me use it.
Im not even using any filters.
Code:LoadPlugin("C:\Users\Admin\Desktop\MeGUI-2913-32\tools\dgindexnv\DGDecodeNV.dll") DGSource("C:\Users\Admin\Desktop\Encoding\TL\Episode 4\MakeMKV\title_t03.dgi",fieldop=0) #deinterlace #crop #resize #denoise
If I take out the loadplugin line it says no function named DGSource. If I use it, nothing on my computer will load the script. I even tried different versions of DGDecodeNV and its the same thing when trying to load the script.
MeGui will make and save the script unless I press the preview button to make an error appear, and then it will freeze after saving it, but it wont open or be able to use the script.
I tried FFMS2 on another version of MeGui and it looks fine in preview again just like DGDecodeNV looked, but when I try to load or use the script it made, I get an error that says "Not an AVISynth 2 C Plugin" whatever that means for the ffms2.dll plugin. I never seen LoadCPlugin in a script before made by MeGui.
LoadCPlugin("C:\Users\Admin\Desktop\MeGui 2715-32\tools\ffms\ffms2.dll")
If I remove the C, I get this again.
If you use a source filter which indexes the source using an external program like ffmsindex or dgdecodenv the index file needs to be created.
MeGui and other GUIs usually automatically create these files and delete them after the program is used.
Since you use DGDecNV, I assume you also have an NVIDIA card, so you could use LSMASHVideoSource as alternative and set prefer_hw=1 for it to use hardware decoding like DGDecNV does.
According to your error, you should use LoadPlugin instead of LoadCPlugin. (there exist C and non-C plugins for FFMS2, so depending on what plugin you use you need to use LoadPlugin or LoadCPlugin).I get an error that says "Not an AVISynth 2 C Plugin" whatever that means for the ffms2.dll plugin. I never seen LoadCPlugin in a script before made by MeGui.
Can't say anything about the artifacts without a sample of the source.
Cu Selur
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Lsmash doesnt work and it has the artifacts/corruption problems too when I tried it in the past. Refer to this old post.
https://forum.videohelp.com/threads/407335-Cant-file-index-or-encode-VC-1
That is the entire reason I even tried dgdecodenv this time is because a long while back it was suggested. It doesn't work for me for whatever reason. it freezes up my MeGui and wont work.
I tried using Lsmash this time and its greyed out in MeGui. It wont even let me select Lsmash in MeGui now for whatever reason. How I got it to work in that old post I don't know. it's forcing FFIndex unless I enable dgdecnv, but dgdecnv does not work and freezes MeGui every time.
Like I mentioned above, if I take the C out, I just get that jumbled letters and symbols error in the image above. I tried manually loading several different versions and releases as well. Older ones work, but they come out all screwed up. Newer ones just error out.
As for a sample, like with most other people in the past who help, it will probably work fine fine for you for whatever reason and not for me.
Here is the video source I'm using.
https://mega.nz/file/x4gWSBCI#anvbJ3Oo72RdvHcAm8tCnGItnuvX82lKYpgpIUPmibo
The artifacts in the screenshot above are at about the 10:44-10:50 mark in the video.Last edited by killerteengohan; 6th Jan 2024 at 03:25.
Did you try with LWLibavVideoSource prefer_hw=1?Lsmash doesnt work and it has the artifacts/corruption problems too when I tried it in the past.
Will look at the source.users currently on my ignore list: deadrats, Stears555, marcorocchini -
1. I can confirm that both LWLibavVideoSource and FFMS2 have issues with the source.
LWLibavVideoSource with prefer_hw=1 even crashes with an access violation error here.
Without prefer_hw=1 it does not crash, but does not properly index the whole source. (seems to be looping a part of the source)
2. DGDecNV works fine here. (are you using the latest version from https://www.rationalqm.us/dgdecnv/binaries/ ?; I'm using "dgdecnv_251.zip 2023-12-17 10:40 3.6M") (for fms2 I used https://codeberg.org/StvG/ffms2/releases/tag/r1391 for L-SMASH I used: https://github.com/HomeOfAviSynthPlusEvolution/L-SMASH-Works/releases/tag/1164.0.0.0)
3. I noticed there's a difference between the frame numbering depending on the sources, but the output seems to be the same:
https://imgsli.com/MjMxMjU3
I used:
andCode:ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadCPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\ffms2.dll") Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi") # loading source: C:\Users\Selur\Desktop\00009.mkv # color sampling YV12@8, matrix: bt709, scantyp: progressive, luminance scale: limited FFVideoSource("C:\Users\Selur\Desktop\00009.mkv",cachefile="J:\tmp\mkv_0cdf27c41d0976b1fd0391618ef64597_853323747_1_0.ffindex",fpsnum=24000,fpsden=1001,colorspace="YV12") # current resolution: 1920x1080 # Converting from 8 to 10bit for encoder ConvertBits(10) # setting output fps to 23.976fps AssumeFPS(24000,1001) PreFetch(16) # output: color sampling YV12@10, matrix: bt709, scantyp: progressive, luminance scale: limited return last
Conclusions so far:Code:ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\DGDecodeNV.dll") Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi") # loading source: C:\Users\Selur\Desktop\00009.mkv # color sampling YV12@8, matrix: bt709, scantyp: progressive, luminance scale: limited DGSource(dgi="J:\tmp\mkv_0cdf27c41d0976b1fd0391618ef64597_853323747.dgi",fieldop=0) Preroll(Int(last.FrameRate())) # current resolution: 1920x1080 # Converting from 8 to 10bit for encoder ConvertBits(10) # setting output fps to 23.976fps AssumeFPS(24000,1001) PreFetch(16) # output: color sampling YV12@10, matrix: bt709, scantyp: progressive, luminance scale: limited return last
a. you might want to report the problem to the FFMS2 and L-SMASH folks.
b. DGDecNV does work for me, but I don't see a difference.
c. I see the aliasing throughout the whole source and would apply some anti-aliasing.
d. I can't reproduce the other errors you mentioned either.
It looks like updating my older avisynth 2.6 to avisynth+ so I can use the newer versions of ffms2 or l-smash appears to fix the issue for me when it comes to this source. I cant test it or encode it, but the preview looked fine.
This updating broke everything I use to encode with and I currently cant get any of my encoders or avspmod to work anymore or I would do a test encode, but I did get one program to load a script and the preview looked fine.
https://forum.videohelp.com/threads/412954-Updating-avisynth-broke-everything-and-AvsP...-working-again
If anyone can help with this, that would be great. If I cant get my encoder or avspmod working with avisynth+, I will have to revert back to the older avisynth and just deal with the artifacts from the looks of it.
mp4 repair untrunc GUI cant work properly/having problems
By DVDLover00 in forum Video ConversionReplies: 11Last Post: 5th Mar 2023, 00:40 -
How to encode 35k videos properly?
By giggioman00 in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2022, 19:15 -
AvsPmod - can't get it to work properly
By pooksahib in forum Video ConversionReplies: 9Last Post: 5th Sep 2021, 05:33 -
VHS doesn't work properly
By vhs-help in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2020, 23:04 -
Cannot properly IVTC
By ZetaStax in forum Video ConversionReplies: 13Last Post: 17th Oct 2019, 17:08
