Page 7 of 8
FirstFirst ... 5 6 7 8 LastLast
Results 181 to 210 of 219
  1. Originally Posted by aqzs View Post
    Originally Posted by sgtpepper View Post
    Hello Aqzs, I tried what you suggested (WITHOUT log level OFF), downloading the lower resolution in order to speed up the procedure and this time I oddly got another error concerning access the C:\ path but I didn't get this kind of error before now.
    Sorry I don't know how permissions are handle on windows, maybe try to download in another folder. You are not supposed to download in C:\
    Try running the command from somewhere else.
    Or add :
    --save-dir 'C:/downloads/'
    partially good news: I managed to download the video without any error (pls see attached picture) and now I got the video as a single playable file but when I try to play it by VLC or other video programs, it tells me codec not supported. Unsupported encoder:
    VLC cannot decode the format " " (No description for this codec). Any idea?
  2. unbelievable. you only have these problems ... VLC can play everything. always.
    which version have you ? latest 3.0.21 ?
  3. Originally Posted by sgtpepper View Post
    Colon (:) is an illegal character for file names, change it or remove the --save-name option completely.
  4. Member aqzs's Avatar
    Mar 2024
    Paris
    The key provided by @lomero isn't the right one.. The right one is (as provided here https://forum.videohelp.com/threads/412937-mediaset-infinity-m3u8-link-not-found/page6#post2739125) :
    7d5e4c8d1351ca9d68a4272a09034045:e7a10bb246f65cbf05cdc551ea992d9e
    Run this command :
    N_m3u8DL-RE.exe "https://vod06.msf.cdn.mediaset.net/farmunica/2024/05/1595592_18fc9abaf1df89/dashrcenc/hd_wv_mpl.mpd" --save-name "D-day: il giorno pił lungo" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --key 7d5e4c8d1351ca9d68a4272a09034045:e7a10bb246f65cbf05cdc551ea992d9e
    Your file : https://www.swisstransfer.com/d/6c7d93a7-903d-49ee-a937-f0a9eb9d5839
  5. Originally Posted by lomero View Post
    Yes unbelievable and unfortunately it happened to me
    I know VLC is a good player, it's 3.0.11 but the other mkv video I downloaded by my friend Aqzs works perfectly so I don't think it's a VLC problem...
    I have also this problem with that file using other video players installed in my PC.
    ps: anyway, I'll soon update it to the latest version, just to avoid....
  6. Originally Posted by aqzs View Post
    Run this command :
    Hello Aqzs, I am now trying again with your code and many thanks again for the file via swisstransfer.
  7. Originally Posted by sgtpepper View Post
    I am the admin. of this machine and I have full control of the system. I've already tried to save on another location inside a folder of the admin user but with no success. Anyway, I will try again to save it just leave no stone unturned.
    Your system seems to have user permission issues on your Windows system
    Just try to fix the permission issue by referring to: Here or Here
  8. Originally Posted by LittleSoldier View Post
    Thanks mate, I am the admin with full complete rights on this machine and I don't think to have any permission problem now.
    I succeeded in downloading the mkv file as a single file but now I have an encoder issue with the file I downloaded (please see attached warnings during procedure by N_m3u8DL-RE.exe utility).
    It's not a problem due to VLC (it's updated now at latest version) o any other player because I downloaded the mkv file that Aqzs sent me and it works perfectly on VLC and the other players.
    Very odd situation!
    In any case, since - thanks to Aqsz - I now have the mkv video file decrypted in HD, I'm going to make another attempt/test by downloading a new video to understand if the same odd problem happens again with a different video.
Name:	mkv error download.jpg
  9. Now, I have created/calculated a new code for another movie that I'm interested in downloading, let's see if it goes smoothly this time.
    If anyone else wants to try downloading it to see if everything goes smoothly for you and make a comparison with me, the code is the following:
    N_m3u8DL-RE.exe "https://vod06.msf.cdn.mediaset.net/farmunica/2024/06/1600840_18ff3228010f89/dashrcenc/hr_wv_mpl.mpd" --save-name "apocalypse-d-day-lo-sbarco-in-normandia" -mt -M format=mkv --save-dir C:/downloads/ --key c9b0eaf751d4a4a2750e2ba4d5f8c12b:387412a1e40e197c0 8231bd758275fe9
    PS: pls note I set saving this file on my C:/downloads/ directory but you can remove "--save-dir C:/downloads/" if you wish.
  10. Friends, I finally managed to download the first movie without any hitches and strange problems.
    I did a quick test by downloading the hr version and everything finally worked perfectly!
    Now, I'm going to download the HD version, for those interested in the documentary the code string is the following:
    N_m3u8DL-RE.exe "https://vod06.msf.cdn.mediaset.net/farmunica/2024/06/1600840_18ff3228010f89/dashrcenc/hd_wv_mpl.mpd" --save-name "apocalypse-d-day-lo-sbarco-in-normandia" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --save-dir C:/downloads/ --key c9b0eaf751d4a4a2750e2ba4d5f8c12b:387412a1e40e197c0 8231bd758275fe9
    Please note, I want to thank so much everyone who helped me in this situation, especially friends Aqzs and Goku73.
  11. Originally Posted by tvsee View Post
    key
    735bbfaceaf3ad2fc1a3c725050a52a0:49659f191ddcebf5d9e130d56096ef3d
  12. Member aqzs's Avatar
    Mar 2024
    Paris
    Download command :
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/07/1706024_19092a56bd0d01/dashrcenc/hd_wv_mpl.mpd" --save-name "Prima puntata" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key 735bbfaceaf3ad2fc1a3c725050a52a0:49659f191ddcebf5d9e130d56096ef3d
    Download link : https://gofile.io/d/otr1mH
  13. Originally Posted by supergirl73 View Post
    key
    Download command :
    thanks
  14. Hello i need help again tho download this one thanks in advance
    https://mediasetinfinity.mediaset.it/video/battitilive/seconda-puntata_F313172601000201
  15. Member aqzs's Avatar
    Mar 2024
    Paris
    Here is the key :
    2cd74987a325a470b407d4d36d8ec4f6:9d57d6d03343406875ac9b0b9e217a88
    Download command :
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/07/1709237_190b71587b2645/dashrcenc/hd_wv_mpl.mpd" --save-name "Seconda puntata" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key 2cd74987a325a470b407d4d36d8ec4f6:9d57d6d03343406875ac9b0b9e217a88
  16. Originally Posted by aqzs View Post
    Here is the key :
    Download command :
    i run N_m3u8DL-RE whith the code but download don't start... can yuu please upload the file on go file? thanks
    [Attachment 80758 - Click to enlarge]
    [Attachment 80759 - Click to enlarge]
  17. Member aqzs's Avatar
    Mar 2024
    Paris
    https://gofile.io/d/WsjylY in a minute nice
  18. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    What's the error message? Show a screenshot
  19. Originally Posted by aqzs View Post
    thanks love you
  20. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    i can't the windows just close after a millisecond
  21. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You aren't doing it right. Go to left corner down, open start, search and open CMD Command Prompt. Type cd your_directory. For example if you N_m3u8 tools are in C:\Users\my_stuff then type cd "C:\Users\my_stuff" . Only then you may drop your N_m3u8 download command. If it doesn't work then, show screenshot with that exact step.
  22. Hi all,
    I'new in this Forum adn very noob with downloading content from Mediaset Infinity. Here are the links to 2 video I'm trying to download without success, I have a Mac and the procedure is vay far my skills:
    https://www.wittytv.it/temptation-island/quinta-puntata-mercoledi-24-luglio/
    https://www.wittytv.it/temptation-island/ultima-puntata-giovedi-25-luglio/
    I would like to have the download link without DRM.
    Thanks in advance
  23. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/07/1785842_190e702bda1645/dashrcenc/hd_wv_mpl.mpd" --key d0ad470900a33394c248f0ccd423aefd:a6dbd523352d05a39259f097fd593301 --save-dir "media\wittytv_it" --save-name "Temptation_Island_Quinta_puntata_-_Mercoledi_24_luglio" -M format=mkv
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/07/1785846_190ec2332ecd01/dashrcenc/hd_wv_mpl.mpd" --key b3ac565d37e7c5aa42f17e87bd1a6809:6de056c16e220204bbd56ce80cea2849 --save-dir "media\wittytv_it" --save-name "Temptation_Island_Ultima_puntata_-_Giovedi_25_luglio" -M format=mkv
    https://www.swisstransfer.com/d/72ae6a9e-a15d-4131-ad5e-9e3b9b9f1ddc
  24. @ 2nHxWW6GkN1l916N3ayz8HQoi.... Thanx so much!!
  25. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Thanx so much!!
    No problem. You can download by yourself from that site using
    python widefrog.py "https://www.wittytv.it/temptation-island/quinta-puntata-mercoledi-24-luglio"
    python widefrog.py "https://www.wittytv.it/temptation-island/ultima-puntata-giovedi-25-luglio"
    It searches automatically for the hidden highest mpd. In your case you had 1080p.
  26. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/10/2120123_192aa3eeca5d01/dashrcenc/hd_wv_mpl.mpd" --key a002248e559a4e1bfd655bb5dd9ec68a:7f13dea96c66642c4d9d82cf25f9d919 --save-dir "media\wittytv_it" --save-name "Amici_Domenica_20_ottobre" -M format=mkv
  27. Code:
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/11/2149844_1937744f9b8d01/dashrcenc/hd_wv_mpl.mpd" --key 110d407b7eabd2828eb42d40fdc25d7a:02b279498689ab560947adf8e76037de -M format=mkv
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/11/2149847_19377491191645/dashrcenc/hd_wv_mpl.mpd" --key 322614abbaf17f829e09b22cdb08678e:43cfbb93880be4cae87e2814a7bda19f -M format=mkv
    N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/11/2149849_1937745c053d01/dashrcenc/hd_wv_mpl.mpd" --key e4e66e1eb9486128387504e7bf81915b:12c682c69c4aa7b970b9de4483fdafad -M format=mkv
