Can anyone give advice on how to append the video files of various sizes and aspect ratios? I mostly deal with emulated game captures but there is an multi emulator BizHawk that split video files when they reach certain aspect ratios and size. The video dumps themselves use the same codecs but sizes and aspect ratios are different. I had used Virtualdub2 and MKVToolnix before but they have their limits and they do not always help. I also heard AVISynth can do something similar but I do not have AVISynth on my Chromebook and the library computers does not have it either unless I use MeGUI. I have a non linear editor called Shotcut that can do the job but I am not sure if it works smoothly or not. What can I do to append the split video files?
Results 1 to 9 of 9
You can try to remux the single videos into a ts container and join the ts chunks.
Or drag and drop all your files onto below batch commandline. The files will be resized to a unified frame size (canvas of 1280x720 as below) and a unified audio (aac). The unified format should make a subsequent concatenation compatible with any tool.
Code:@echo off :next if "%~1"=="" goto done ffmpeg.exe -y -i "%~1" -c:a aac -c:v libx264 -preset slow -crf 20 -filter:v "scale=w=1280:h=720:force_original_aspect_ratio=decrease,pad=1280:720:(ow-iw)/2:(oh-ih)/2" "%~1_resized.mp4" shift goto next :done pause
You could try also the ffmpeg concat (protocol or demuxer).
More info here:
https://trac.ffmpeg.org/wiki/Concatenate -
Surveillance Footage from Bus, Aspect Ratios, Frame Rate
By evanhem in forum Newbie / General discussionsReplies: 0Last Post: 25th Sep 2022, 23:21 -
Converting Video Files to Specific Sizes
By devilcoelhodog in forum Video ConversionReplies: 5Last Post: 2nd Oct 2021, 10:06 -
Issues/ Tips When Managing Clips with Different Aspect Ratios
By Hellogoodbye in forum EditingReplies: 0Last Post: 10th Jan 2021, 03:39 -
MKVToolnix Muxing Append Error: Can't Append File to Itself
By koberulz in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2019, 15:58 -
Ripping Resolution/Aspect Ratios
By BYJAM in forum DVD RippingReplies: 8Last Post: 27th Jul 2019, 13:38
