Hi, I have been experiencing a really minor problem for months but I'm curious if it happens only to me. With both MPC-HC and MPC-BE if I click on "File" it takes between 4 and 5 seconds to show the menu. It doesn't happen with the other like "View" "Play" "Navigate" etc.. Both applications are up to date. I experience the same problem even after a clean reinstallation of windows!. I would be happy to understand what produces this small, but I admit, very irritating problem.
My PC is:
Windows 11 Pro, Ryzen 9 3900X, 64 GB RAM 3200 MHz DDR4, GeForce RTX 2070 Super, SSD Samsung 970 Evo Plus 250 GB
I couldn't find that entry, I think because the discussion is 13 years old
That's true, but nevertheless there may be a clue in that it is related to some device in your system
Unbelievable, man! You were right!!! Thank you very much!!! Since I couldn't find that item in the applications settings, I tried disabling the cd/dvd-rom player in windows devices. Problem solved. So it's true. It depends on that. If I find how to disable it only in applications maybe I can re-enable it on windows.
In any case, I don't understand why the problem has arisen only now.... I have had the same cd-rom drive for a very long time. MPC-HC and MPC-BE have never had this problem. I have tried using older versions of both applications, versions that had never had problems with the cd-rom, and the problem occurs with them as well. Incomprehensible
Win7, MPC-HC says "Stopped" when trying to play some files after waking up
By Rekrul in forum Software PlayingReplies: 4Last Post: 24th Oct 2023, 03:10 -
Stripping "Writing Library" & "Encoding Settings" Metadata Off a File While
By simon744 in forum Video ConversionReplies: 0Last Post: 14th Aug 2023, 11:53 -
The ''pause'' button on MPC (capturing)
By Litaiff in forum EditingReplies: 0Last Post: 1st Apr 2023, 04:27 -
Any Google Drive "addon" for MPC-HC?
By stranno in forum Software PlayingReplies: 0Last Post: 11th May 2019, 14:55 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 08:25
