Happy new year!
Yesterday I recorded a football game from my DirecTV HD DVR on my Panasonic DMR-EZ28 in XP mode. I filled about four DVD+RW discs. My plan was to capture the game in the highest possible quality on my DVD recorder, then remove commercials in TMPGEnc Authoring Works 6 and have the program shrink the resulting output to fit on a DVD+R DL disc.
In terms of picture quality, would I have been better off capturing the game in SP mode, editing out the commercials in TMPGEnc AW6, and then just merging all the clips together without re-encoding? This might not completely fill the disk, but it would be close.
I guess the general question is whether it is best to capture in the highest quality possible, then compress a little bit more via software, or to capture at a slightly lower quality and avoid having to compress via software.
Thanks.
Yeah it is probably best to use as high quality as possible to get best results after editing / removing commercials to then allso encode the video to an format+codec more suited to acctually play the video in basicly any video player there is, which the result very often is an smaller file size allso! Atleast since im guessing the format and or the codec is the one that come from the recorder which is maybe not fully encoded or compressed just yet and is still some sort of raw format/codec or similar! But if it is allready the format and codec you want and you can get rid of the commercials without re-encoding i guess it could work out fine this way allso with a lil bit lower quality from the beginning!
Edit: Im not really sure what this XP and SP mode is when im answering this! -
Before I had an HTPC, I used to record a lot of TV using a DVD recorder. IMO, if you want the entire game on one DVD disc you would be better off capturing in SP mode, removing the commercials with TMPGEnc Authoring Works 6, and authoring a DVD on DVD+R DL media, assuming the edited and merged video will fit.
If you have a Blu-ray burner and you want a higher-quality recording, you could record the game in XP mode and save the edited file from TMPGEnc Authoring Works 6 (without authoring it) on a BD-R (recordable single-layer 25GB Blu-ray disc). Blu-ray players can play an unauthored DVD-quality video file from burned Blu-ray media. I rarely author anything these days. Instead, I copy my recorded TV files to Blu-ray to have a backup copy.Last edited by usually_quiet; 2nd Jan 2024 at 12:27.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
As I recall, TMPGEnc Authoring Works 6 is capable of editing using "smart encoding", meaning only the GOPs on either side of a cut are re-encoded and the rest of the GOPs in the file will simply be copied. In that case, the quality loss from editing is minimal.
If Dawgsfan plans to author a DVD from his edited file using TMPGEnc Authoring Works 6 there is no reason to re-encode his edited video to a more efficient codec. If he doesn't want to author a DVD from his edited file and merely wants to store a file on a DVD-R then he could record in XP mode, then reencode with a more efficient codec to make the re-encoded file small enough to fit on a DVD-R or DVD+R DL. ...but at the cost of losing some quality. Will the quality loss be noticeable? That is hard to say.Last edited by usually_quiet; 2nd Jan 2024 at 19:41.
TMPG Authoring Works - Batch Authoring tool not launching
By lj01 in forum Authoring (DVD)Replies: 4Last Post: 4th Sep 2024, 12:14 -
My LG DVD recorder are formatting my Philips DVD-RW disks in a endless loop
By Joscraft_05 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 29th Sep 2023, 22:44 -
ML/AI based video editing? Finding patterns in editing footage.
By GoodEnough in forum Newbie / General discussionsReplies: 9Last Post: 9th May 2023, 18:22 -
DVD Authoring
By mugz8391 in forum Newbie / General discussionsReplies: 10Last Post: 9th Aug 2020, 12:59 -
Panasonic DMR - EH59 DVD Recorder won't format double layer blank DVD's
By pelk12 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2019, 11:01
