    Sep 2021
    I'm joining 4 separate scripts together before I encode. They were originally one tape. I wasn't sure if v1+v2+v3+v4 is ok or is ++ better? Thanks
Name:	joining scripts before encode.JPG
  2. The difference is unaligned splicing (+) vs aligned splicing (++).
    I would start with ++ and check if audio and video are in sync. If not, try +
    Sep 2021
    Thanks Sharc. I will try ++.
