Hi,
Trying to update keys for NOWTV Uk live channels that change once a month.
Anyone know how to request a new updated key from cdrm-project.com?
For example:
AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEAADid stbpMNJr7WNWqz4cdI49yVmwY=
Always refers to the old cached PSSH key from Dec 5 that no longer works.
I have tried checking/ un-checking cache, but makes no difference?
This site works, as it provides the right key for VOD demand from the same vendor.
Would have thought if the key requested is different it would ignore and update the cache key?
Cheers
Steve
?? cdrm-project.com ___ findpssh work fine ...
Code:000389db2d6e930d26bed6356ab3e1c7:c26fec6717118399cc5f30df717c27fe
[Attachment 75892 - Click to enlarge] -
Thanks Lomero,
My question is not that cdrm-project.com can generate the key?
pssh - AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEAADid stbpMNJr7WNWqz4cdI49yVmwY= is from a live channel and the key has changed.
How do you generate a new key from a existing cached pssh that has had a key change?
Hope that makes sense. -
Please help me to understand this.
Are you saying/implying that the that the key has changed but the pssh did not change?
My understanding that the (pssh) keyid : key is a pair. If the key changes then the kid should change hence the pssh should change.
Code:AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEAADidstbpMNJr7WNWqz4cdI49yVmwY= "keyIds":["AAOJ2y1ukw0mvtY1arPhxw=="], "protectionScheme":1667591779 -
It's not always the case for live key rotation.
The PSSH in the MPD may have an old KID.
The init (initial segment) also has the old KID.
So, we generate the newest KID from the new segments and create PSSH from it.discord=notaghost9997
CDRM Project Dead?
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 48Last Post: 16th Nov 2023, 08:52 -
Cdrm-Project Similar
By rekox in forum Video Streaming DownloadingReplies: 13Last Post: 10th Aug 2023, 14:14 -
cdrm-project.com errors
By euphonic in forum Video Streaming DownloadingReplies: 13Last Post: 27th Jul 2023, 05:30 -
Problems with cdrm-project.com
By corvo4791 in forum Video Streaming DownloadingReplies: 11Last Post: 27th Apr 2023, 16:53 -
Help to use cdrm-project.com
By vidsrme in forum Video Streaming DownloadingReplies: 6Last Post: 26th Mar 2023, 05:11
