Is there any filter at AviSynth which warps the chroma to the luma edges to try to achieve precise color resolution?
Awarpsharp , Awarpsharp2 has a chroma mode that is guided by luma (the default mode=4)
eg where you adjust the depth value
Code:MergeChroma(AWarpSharp2(depth=x))
ChromaReconstructor , but it's very slow
http://forum.doom9.org/showthread.php?t=173005
Another is using various neural net upscalers on the chroma planes
AIUpscale has some chroma modes , but there are many other types of upscalers you might use on the chroma (not necessarily avisynth only either)
https://forum.doom9.org/showthread.php?t=181665
Avisynth: how to get rid/mask this kind of green artifacts?
By elektro in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2023, 10:57 -
AviSynth Dissolve Filter
By jseo13579 in forum EditingReplies: 1Last Post: 10th Feb 2022, 23:08 -
Any video hardware designers know the parameters of the edge sharpen filter
By Ian Jaffray in forum RestorationReplies: 2Last Post: 23rd Nov 2021, 05:31 -
what's the best AviSynth denoising filter?
By pm-s in forum Video ConversionReplies: 2Last Post: 17th May 2021, 21:09 -
Chroma Ghosting on AviSynth IVTC
By BruceKaneWayne in forum Video ConversionReplies: 3Last Post: 24th May 2020, 15:26
