I captured DV tapes over Firewire with VRecord. VRecord does not have an option to change the levels coming off of DV tapes. It simply packages the DV stream precisely as it comes off the tapes into a .dv wrapper. Some of the tapes have color bars. When I view the files using FFPlay's waveform display the black bar in the color bars is elevated above digital 16 at 7.5 IRE. Supposedly DV recordings were never made with analog setup. Is it possible that some DV family of camcorders had an option to add it? Can anyone explain this? Thx.
You may want to take a look here. There are cameras mentioned which do it right or wrong. Applies for "NTSC" only, anyway.
http://www.kenstone.net/fcp_homepage/video_levels_nattress.html
Here is my Setup. What do you think?
By plehoediv in forum Capturing and VCRReplies: 103Last Post: 22nd May 2023, 11:39 -
Converting Audio Files with 5.1 to play on DVD surround sound setup
By rayhigh in forum AudioReplies: 1Last Post: 4th Jan 2022, 14:04 -
Adjusting IRE Black Levels with Sony DV Camcorder Pass-Through Capture
By VideoDoc in forum Capturing and VCRReplies: 8Last Post: 15th Apr 2020, 04:34 -
Help with my capture setup
By DocSnyd3r in forum Capturing and VCRReplies: 3Last Post: 16th Jan 2020, 14:04 -
8mm Film to DVD - Is 7.5 to 115 IRE Normal?
By Eric H. in forum Newbie / General discussionsReplies: 14Last Post: 6th Aug 2019, 07:41
