Which one has the better and higher quality, upscaling an image or upscaling a video?
If the former is true, is R-ESRGAN 4x+ the best upscaler for both normal and anime photos? What are some programs or websites that I can use it locally?
It depends on the upscaling method or algorithm used, and the source
IF you use single image neural net upscaler, there will be no difference, as only 1 frame is processed at a time, and the majority work in RGB anyways. Often a problem with single image upscalers when used on video , or an image sequence is flicker and temporal inconsistency
If you use video or temporal upscaler , they can make use of multiple frames and that can sometimes produce better results assuming you meant an image sequence, not a single image
I would say probably not , but it depends heavily on the source and specific models used. It's one of those things you have to test and try. There are hundreds of models and upscaling architectures . Many of the open source ones use python
If your source is very close to the training set used to train the model, the results should be good.
But there are many different types of anime styles, many different types of "normal" photos. A single model for everything would look terrible. You need a specific model for the best results
The best upscales generally make use of pre and post processing appropriate for the source
Chainner and cupscale can use many upscaling architectures, vapoursynth has access to many as well
https://github.com/chaiNNer-org/chaiNNer
https://github.com/n00mkrad/cupscale -
For "neural net" or 'AI" category, usually the ones that were trained on sources that are most similar to your videos and images
You often have to use other filters in combination if you want best results . You almost never get the "best" results using 1 upscaling filter only -
You buy the original movie and video game sources
If no free publicly available models exist in your category, then you can try to train custom ones for best results. Otherwise you have to use non specific models and conventional techniques and filters
There are various forums and discussion boards, discord for upscaling . Some have private models
Often you have to pre/post process sources (not all sources are pristine to begin with, not even BD) -
Here is an upscaled Blu ray movie.
https://www.blu-ray.com/movies/Dragon-Ball-Super-Super-Hero-4K-Blu-ray/343894/
This is also a hd collection of remastered games.
https://slycooper.fandom.com/wiki/The_Sly_Collection -
Beware that sometimes a retail upscale isn't done very well . Often a studio will do a poor "rushed" job of an upscale . Sometimes you can find alternate methods and scripts with comparisons in various fan forums that sometimes do a better job
There are many game mods and upscaled textures for various games and platforms, just do search. There are forums dedicated to game upscaling. Many of the older upscales used ESRGAN derivatives, but there are newer engines now
Grain??? Before or after Upscaling?
By salvo00786 in forum DVD RippingReplies: 8Last Post: 4th Nov 2022, 15:09 -
Upscaling to 4k?
By BlurayHD in forum Newbie / General discussionsReplies: 25Last Post: 23rd May 2022, 12:54 -
Ai Enhancing and Upscaling
By magnu in forum RestorationReplies: 4Last Post: 14th May 2021, 07:13 -
Is A.I. Upscaling Better than QTGMC?
By AndersonJames in forum Video ConversionReplies: 8Last Post: 20th Aug 2020, 14:40 -
Upscaling
By DiggyDre in forum EditingReplies: 2Last Post: 16th Feb 2019, 20:42
