I have the 4. k Blu Ray of Black Widow.
I got this a fue Years ago and used MakeMKV to put it on my USB Hard Drive.
I wanted to check the Specs. on the mkv File I made so I opened it in MediaInfo.
I Audio is 8. CH. this is what I selected so this was Right.
The Res. says 1920X1080 this is not 4. k what is going on?
I thought MakeMKV took the 4. k and put it in an mkv File?
What is going on?
Results 1 to 27 of 27
Purchased UHD Blu-ray movies often include a Blu-ray disc too. Possibly you decrypted the Blu-ray copy by mistake.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
AnonymousGuest
You need a 4k capable drive to rip the movie. A standard bluray drive is not (there are models that can be converted though)
The key is updated frequently as outlined here: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Warning! I'm baaaaaaaaack -
I did put that code in and it opens but it tells me No Disc In Drive.
It does scan the Drive and I here it and the Bars go across the screen.
I just do not know why it would stop now.
I did try to install the Blu Ray Program Leawo Player and I could not get it to work.
Is there another Free but Basic Blu Ray Player I can try? -
Ok I Re Installed the DVD Program I posted.
Then I opened AutoPlay and set everything.
I Plug my USB Blu Ray in and I can play my Blu Rays.
I then opened MakeMKV and put in my Blu Ray of Wrong Turn.
MakeMKV Loaded the Disc and I pick everything to save to the Hard Drive.
Everything worked good.
So I opened the Wrong Turn Movie that it put on my Hard Drive.
The Res. says 720X480 and also it says it is 4:3 Ratio.
This is a 4. k Blu Ray what is going on?
I thought I would try it again and MakeMKV tells me No Disc In Drive.
If this is a MakeMKV Problem is there any other Free Program to Copy Blu Rays to Hard Drive? -
I don't know of any other free UHD Blu-ray rippers that you could use instead of MakeMKV.
For test purposes, I just tried ripping my UHD Blu-ray of "Avatar: The Way of Water" using the latest trial version of MakeMKV. I used the internal 5.25-inch Blu-ray drive installed in my HTPC. It is standard a Blu-ray drive with the ability to read and burn BDXL recordable media. It is an LG WH14NS40, which is a known "UHD-friendly" drive. I didn't flash it with replacement firmware.
MakeMKV says the drive has its original firmware and shows Libre Drive as enabled. After I clicked on the "Backup" icon and checked the decryption box in MakeMKV, I was able to successfully copy the entire disc to an HDD as Blu-ray decrypted files and folders.
MediaInfo says the MTS files containing the movie are 3849x2160 resolution. The individual MTS files are playable using VLC I installed Leawo Blu-ray player and the main movie started playing at the beginning. I didn't watch the whole movie to find out if Leawo Blu-ray could play the entire movie correctly since Avatar: The Way of Water is not a short film.
Unless you are not using a genuine UHD Blu-ray disc or your external Blu-ray drive is not a"UHD friendly" model I don't know what is causing your problem.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
AnonymousGuest
Another possibility would be that the drive is revoked. This happens when a newer aacs key from disc is read by the drive, it revokes all older keys. In that case you need a makemkv version that has a higher aacs key then the disc.
This won't be a problem if you have a drive that is libreDrive capable -
While this scenario is possible, it is not common. From what I was able to find online, it seems to show up mostly when someone is using VLC to play a Blu-ray on a computer running Linux.
If I put a Blu Ray Disc in Leawo Blu-ray Player opens and Plays the Blu Ray.
So my System can see the USB Blu Ray Drive
So I open MakeMKV and put a Disc in and this time I select my Blu Ray Drive from the list.
It scans the Disc and says No Disc.
So it is not my Drive because my System Plays it.
It is not my System because my Computer Plays it.
So it must be MakeMKV.
I was going to Try HandBreak but I did not know if this was just for Converting Files? -
I just put a Plane DVD Movie I have in and MakeMKV Scanned the Disc and gave me all the Titles to check or un check.
It put them all on my Computer ok.
It may be my USB Drive I have so I put what I have here.
NaCot External Blu Ray CD DVD Drive 3.0 Blu Ray Burner Reader BD CD DVD WR ROM for iMAC or PC MacOS Windows Black NKL27BLO
Is this of any help?
Do I need a Driver to play 4. k Blu Rays? -
AnonymousGuestHow come you think it will rip uhd disks?, only certain bluray drives can be upgraded by loading a adjusted firmware, i can't tell if yours qualifyBlu Ray Burner
more info here
https://www.dvdfab.cn/4k-uhd-drives.htm -
I looked at the Amazon listing for your drive and read some of the reviews. It might be using refurbished used drives and doesn't seem like a reliable product. Long story short, I think you need to find a different, better-quality drive with known support for UHD Blu-ray ripping.
Based on the description, your NaCot drive appears to have the ability to both read and burn CDs and DVDs but is read-only for Blu-ray. The description explicitly says your drive can't read 4K/UHD Blu-ray discs. I didn't see the sort of specs that I normally see for any optical drive from a reputable brand so there is no way to tell if it can read BDXL media.
To rip retail UHD Blu-ray discs, a BD drive needs to be a true UHD Blu-ray drive or to have the ability to read BD-XL media. However, not all drive models with those specs are compatible. There is a list of drives known to support Blu-ray ripping in the MakeMKV forums. DVDFab has a similar list. As I recall, there aren't many slim USB drives on either list.
[Edit] Below is a link to a post at the MKV forums containing a list of current (as of 1/31/2023) compatible Blu-ray drive models with original firmware versions that allow them to be LibreDrives without flashing new firmware. Compatible drives and compatible firmware combinations are found under sections in the list marked "compatible".
https://forum.makemkv.com/forum/viewtopic.php?p=79712#p79712Last edited by usually_quiet; 31st Dec 2023 at 14:24.
Thank you for all the help and time.
I live in the USA and I see a lot of USB 3.0 4. k Blu Ray Drives on Amazon.
Is there any good one under $ 100.00 on Amazon? -
Unfortunately, slim Blu-ray drives are less durable than full-height Blu-ray drives and need to be replaced more frequently but if that is what you need, there are a few slim USB 3.0 external Blu-ray drives that can read BDXL media and are on MakeMKV's or DVDFab's list of models that work for ripping UHD Blu-ray. This is one of the ones on MakeMKV's list https://www.amazon.com/LG-Electronics-External-Optical-WP50NB40/dp/B011327QXC/ However, recently manufactured units will need to be flashed with new firmware to rip UHD Blu-ray discs. I have a feeling that you may not be comfortable doing that. If so, there are people on MakeMKV's forums that sell pre-flashed drives at a significantly higher price.
Read this thread about flashing: https://forum.makemkv.com/forum/viewtopic.php?t=19634
YouTube video demonstrating how to flash a drive with that has encrypted firmware - https://www.youtube.com/watch?v=jyQV1aPlbowLast edited by usually_quiet; 1st Jan 2024 at 10:25.
Would this be good?
I did not see if it is a 4. k Blu Ray Player.
https://www.amazon.com/dp/B09PBF8SMG/ref=syn_sd_onsite_desktop_0?ie=UTF8&pd_rd_plhdr=t...CMNOuw7lSi1y9Y -
If you buy a Blu-ray drive now that is compatible with ripping UHD Blu-ray, there is a nearly 100% chance that it will need to be flashed with alternative firmware for ripping. I have two full-height 5.25-inch internal Blu-ray drives that are both on the list of models that are compatible with MakeMKV for UHD Blu-ray ripping, an LG WH14NS40 (purchased in 2016) and an LG WH16NS60 (purchased in 2019).
The LG WH14NS40 is not a UHD Blu-ray drive but reads BDXL media. It was new enough to support UHD Blu-ray ripping but old enough that it did not need to be flashed with other firmware to become a Libre Drive. Its installed firmware version is so old that it includes no safeguards to prevent ripping UHD Blu-rays. Otherwise, it would have needed to be flashed. This model is still sold but it will almost certainly need to be flashed on account of being manufactured more recently,
The LG WH16NS60 is an official UHD Blu-ray drive that I bought specifically for watching UHD Blu-rays with a BDA-approved version of Cyberlink PowerDVD Ultra that allowed it. I flashed it after Microsoft and Intel removed support for SGX so I could continue watching my UHD Blu-ray discs, although I must use other software video players that are not subject to the BDA's requirements. This model is no longer made and is hard to find. If you manage to get one, it will also need to be flashed with new firmware.Last edited by usually_quiet; 1st Jan 2024 at 16:03. Reason: clarity
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 19:04 -
1 blu ray movie 80gb in 2 blu ray of 40gb
By killbill831 in forum Authoring (Blu-ray)Replies: 2Last Post: 18th Oct 2022, 22:44 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 12:02 -
Mitsun(Mit-blu 3100) Blu-ray Player not support or playing?
By Shreeux in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Jul 2019, 11:54 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11
