Is there a tool (not counting Bulk Rename Utility) that can number files (and not just only in alphabetical order) while also keeping their original names?
Never mind, I found a tool called Flash Renamer where you can drag the files in the order you want them to. The unregistered version is not limited in any way, all features are free.
https://www.rlvision.com/flashren/ -
I also found this tool called Advanced Renamer. For personal home use, it's free of charge.
https://www.advancedrenamer.com/ -
I would also suggest Advanced Renamer. It allows you to add a numerical sequence to filenames while preserving their original names. Give it a try!
I like ReNamer (http://www.den4b.com/products/renamer) for renaming files.
Tool to check for errors in H.264 mp4 video files?
By guy24s in forum Software PlayingReplies: 12Last Post: 20th Aug 2022, 03:30 -
Subtile numbering not in chronological order
By loninappleton in forum SubtitleReplies: 18Last Post: 14th Jul 2022, 00:28 -
Tool to trim, cut, merge video files
By galapogos in forum EditingReplies: 1Last Post: 29th Dec 2021, 11:25 -
Looking for Batch Remux Tool to Combine MP4 with Bluray Subtitle Files
By AndersonJames in forum Video ConversionReplies: 0Last Post: 29th Jun 2020, 07:10 -
tool to check video files for freezes? (downloaded with letmeatit)
By schmutzbrust in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2020, 17:47
