I have just burned few short movies (.mpg or .dat ) into a cdr by using nero. I have create a menu before i burned it into the cdr.The problem is that the menu doesn't appear when i played the cdr in my cd player, the other portions work well ( I mean the movies ). But, the menu appears when i try to played in my cd-rom.Can any one figure out the reason?please help on this. Thanks.
If this is a high resolution MPEG still, I read somewhere that some DVD players don't like to play stills if they are the first thing in the playlist. The fix would be to add a short (5sec?) video at the beginning of the VCD. Try it on a CD-RW first.
Its also possible (although a bit unlikely) that PBC is turned off on your DVD player. If there is a PBC button on the remote, make sure that it is on before playing the VCD.
multiAVCHD menu problem
By Clydesdale in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2013, 22:36 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 06:06 -
TAW4 menu problem
By Yaro in forum Authoring (DVD)Replies: 0Last Post: 7th Sep 2009, 09:39 -
FAVC Menu Problem
By marioval in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2008, 05:05 -
Menu Aspect Problem
By meeky in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Sep 2007, 04:09
