H.265 videos have higher quality than H.264 videos, right? So if I encode an original Blu-Ray H.264 video into a H.265 video, will the output video result in having higher quality than the original source?
No, and you're mixing up generations
h265 can have higher compression than h264, but it depends on the encoder, settings used
Quality always goes down when you re-encode with a lossy codec. Generation loss . You can never recover the lost data. You can never improve a video just by using lossy encoding - it ALWAYS gets worse .
Even if you used a lossless codec and increase the filesize 10x, that just prevents more quality loss. 10x larger but same quality
You can NEVER get better than the input source, just by using encoding . (Sometimes you can use filters and make some subjective improvements)
But if you started with the blu ray master (the source used to encode the retail blu ray - these are not publically available), then
a) used h265 with "x" bitrate
or
b) used h264 with "x" bitrate to make the original blu ray
Then (a) should be less bad than (b) the retail blu ray, but both are still worse than the Blu ray master (which is the input source in this case) . The retail blu-ray is a lossy encode from the blu-ray master. You cannot get the details back that the original master had from using the retail blu-ray as a source. It's forever goneLast edited by poisondeathray; 28th Dec 2023 at 20:35.
No. You can't increase the quality of a video just by re-encoding, regardless of the codec you use. The best you can do is keep the quality the same, and that is only possible using a true lossless codec.
H.265 encoding isn't used to increase quality. It is used because it can significantly decrease file size for HD and UHD video without making video quality much, much worse than the original.Ignore list: hello_hello, tried, TechLord, Snoopy329
FFmpeg H.264/265 lossless
By Jay123210599 in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2023, 22:01 -
Moving from x.264 to x.265
By Ninja Joe in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2023, 13:05 -
AVC, h.264, MPEG4-Version10, h.265 MPEG-H
By Litaiff in forum EditingReplies: 5Last Post: 22nd Feb 2023, 22:42 -
Differences between ripping H.264 and H.265
By vieekk in forum Video ConversionReplies: 10Last Post: 23rd Dec 2020, 21:33 -
Batch convert H.265 MKVs to H.264
By Nico Darko in forum Video ConversionReplies: 2Last Post: 28th Jun 2020, 17:09
