I have a DVD recorder Pioneer DVR-540H-S which I used many years ago but was shelved until recently.
It has SCART connector that connects to my Sony TV which also has a SCART connector.
The picture quality for the menus is not so great.
It has also component output which I can connect to the TV, but I have never tried that because in the past I didn't have a long component cable.
I have ordered a component cable yesterday 1.8m long so that should be long enough. It can take few weeks to arrive.
My question is if I will see any noticeable difference when I use the component cable?
Results 1 to 9 of 9
Component is the best you can get. Three individual baseband signals Y, Pb, Pr, unmodulated, no sharing or muxing. You should be surprised. But it can't be better than the source of course.
Scart is pretty old and sometimes not the best quality but seem to allways be working and is real easy to setup!
Component is better but if the menus are poor through SCART it suggests the composite channel is being used. The menus are generated internally in the DVD machine so they should be high quality. SCART can carry component, RGB or composite, I suspect you are using the composite signals.
Brian. -
Thanks Brian. That's interesting. You are right I have three options to select. Composite, RGB and S-Video. I have selected the composite option. Will try the other options and see if I see a noticeable difference. But will the component connection be better than any of those options?
Your SCART cable and connectors need to be "fully wired" to support all options. It's advantage is that it supports video and audio.
RGB and Component is not necessarily the same, but sometimes used exchangeably. You have to try. How are the RCA connectors on the Player and TV labelled?
https://en.wikipedia.org/wiki/Component_video
Quality (from high to low):
1. Component (Y,Pb,Pr) (or sometimes incorrectly referred to as "RGB")
2. S-Video
3. CompositeLast edited by Sharc; 28th Dec 2023 at 08:56. Reason: Typos
I will make a test after the component cable arrives.
The remote buttons are all sticky making the navigation a nightmare. I ordered a replacement hopefully it will arrive with the cable.
Thank you all for your help. -
I like the look of composite better than S-video
By JVC in forum Capturing and VCRReplies: 5Last Post: 13th Dec 2023, 17:07 -
VirtualDub2 - Display video pane on a secondary display?
By simple in forum Video ConversionReplies: 0Last Post: 17th Sep 2021, 12:54 -
Composite vs DV vs S-Video Comparison
By GrouseHiker in forum Capturing and VCRReplies: 32Last Post: 31st May 2020, 14:57 -
Best choice of composite upscaler for HD capture
By nsputnik in forum Capturing and VCRReplies: 3Last Post: 16th Apr 2020, 15:32 -
MPC and VLC display video differently by colorspace and component range
By vice2 in forum Software PlayingReplies: 4Last Post: 9th Aug 2019, 14:31
