Remove ads segments from Goplay SSAI mpd
Create mpd no ads template code using awk, sed and grep for Windows OS
cat ads.mpd | sed "/Period.*-ad-/,/\/Period/d" | sed "/Representation.*height..[457]/,/\/Representation/d" | sed -z "s#\/Period.*\n.*MPD#/Period>\n</MPD#" | sed "/SegmentTimeline/{n;:l N;/\/SegmentTimeline/b; s/\n//; bl}" | awk "/\074S d/ && ++count==1{sub(/\074S d.*$/,\"\074qqqqq_video\076\")} 1" | awk "/\074S d/ && ++count==1{sub(/\074S d.*$/,\"\074qqqqq_audio\076\")} 1"
code explanation
cat ads.mpd
This lists the contents of the file ads.mpd. This list is then piped into the stream editor sed
This code deletes all lines between and including any period that has -ads-
This code deletes all lines between and including any period that has Representation with height starting with 4,5 or 7.
With this line of code we have scraped the best resolution with height 1080
This code deletes all the Period data except the first. The 1080 Period is the first
This code concatenates all the SegmentTimeline lines
There are two sets of SegmentTimeline data ... video listed first and audio listed second
Next task is to reidentify this data so that we can later do a find/replace when injecting the complete SegmentTimeline data
This code replaces the first found SegmentTimeline data (video) with <qqqqq_video>
We have also replace the hook data <S d for this SegmentTimeline data
We repeat the code.
This code replaces the first found SegmentTimeline data. This is now the audio data. We replace it with <qqqqq_audio>
We now have the complete remade mpd.
All that is required is to add the video and audio SegmentTimeline data via another sed replacement.
End of Part One
Part Two ... Capturing the video and audio SegmentTimeline data
cat ads.mpd | sed "/Period.*-ad-/,/\/Period/d" | sed "/Representation.*height..[457]/,/\/Representation/d" | sed -n "/SegmentTimeline/,/\/SegmentTimeline/p" | sed "/SegmentTimeline/{n;:l N;/\/SegmentTimeline/b; s/\n//; bl}" | grep -v "SegmentTimeline" | awk -v row=2 "BEGIN {}{A[(NR-1)%row]=A[(NR-1)%row]$0\"\";} END { print A[0]; }" | sed -e "s#/>#/>crlf#g" | gclip
This code captures all the SegmentTimeline data .... at this point this is all 1080 data
This code concatenates all the SegmentTimeline data
this code removes all lines with the string SegmentTimeline
At this point we have video and audio data in alternate lines. We need to filter them out
This code will collate alternate lines 1 3 5 7 etc and 2 8 6 8 etc
video (odd) lines ... stored in A[0]
audio (even) lines ... stored in A[1]
Each array is printed out and stored in the clipboard
for /f "tokens=*" %e in (' pclip ') do set v_data=%e
This line of code stores the clipboard into a variable
Two variables are created v_data and a_data
This data is then injected into the template (created in part one)
sed -e "s#<qqqqq_video>#%v_data%#" and
sed -e "s#<qqqqq_audio>#%a_data%#"
Here is the complete code
Code:cat ads.mpd | sed "/Period.*-ad-/,/\/Period/d" | sed "/Representation.*height..[457]/,/\/Representation/d" | sed -n "/SegmentTimeline/,/\/SegmentTimeline/p" | sed "/SegmentTimeline/{n;:l N;/\/SegmentTimeline/b; s/\n//; bl}" | grep -v "SegmentTimeline" | awk -v row=2 "BEGIN {}{A[(NR-1)%row]=A[(NR-1)%row]$0\"\";} END { print A[0]; }" | sed -e "s#/>#/>crlf#g" | gclip for /f "tokens=*" %e in (' pclip ') do set v_data=%e cat ads.mpd | sed "/Period.*-ad-/,/\/Period/d" | sed "/Representation.*height..[457]/,/\/Representation/d" | sed -n "/SegmentTimeline/,/\/SegmentTimeline/p" | sed "/SegmentTimeline/{n;:l N;/\/SegmentTimeline/b; s/\n//; bl}" | grep -v "SegmentTimeline" | awk -v row=2 "BEGIN {}{A[(NR-1)%row]=A[(NR-1)%row]$0\"\";} END { print A[1]; }" | sed -e "s#/>#/>crlf#g" | gclip for /f "tokens=*" %f in (' pclip ') do set a_data=%f cat ads.mpd | sed "/Period.*-ad-/,/\/Period/d" | sed "/Representation.*height..[457]/,/\/Representation/d" | sed -z "s#\/Period.*\n.*MPD#/Period>\n</MPD#" | sed "/SegmentTimeline/{n;:l N;/\/SegmentTimeline/b; s/\n//; bl}" | awk "/\074S d/ && ++count==1{sub(/\074S d.*$/,\"\074qqqqq_video\076\")} 1" | awk "/\074S d/ && ++count==1{sub(/\074S d.*$/,\"\074qqqqq_audio\076\")} 1" | sed -e "s#<qqqqq_video>#%v_data%#" | sed -e "s#<qqqqq_audio>#%a_data%#" | sed -e "s#crlf#\n#g" | sed -e "/^$/d"
Results 31 to 34 of 34
Been using this for over a year now:
VB.NET:
Works every timeCode:Private Function FixGoPlayMPD(MPDUrl As String) Dim MPD As XDocument = XDocument.Load(MPDUrl) Dim ns As XNamespace = MPD.Root.GetDefaultNamespace 'This removes the ads MPD.Descendants(ns + "Period").Where(Function(n) n.Attribute("id").Value.ToString.Contains("-ad-")).Remove 'Get This highest bitrate Dim HighestBandwidth As Integer = 0 Dim Bandwidths = MPD.Descendants(ns + "Representation").Where(Function(n) n.Parent.Attribute("mimeType").Value.ToString.Contains("video")) For Each x In Bandwidths If CInt(x.Attribute("bandwidth").Value) > HighestBandwidth Then HighestBandwidth = CInt(x.Attribute("bandwidth").Value) End If Next 'Remove all VIDEO Periods that are not the highest bitrate MPD.Descendants(ns + "Representation").Where(Function(n) n.Attribute("bandwidth").Value.ToString <> HighestBandwidth.ToString And n.Parent.Attribute("mimeType").Value.ToString.Contains("video")).Remove 'Now we are going to concatenate the different periods into one Dim newvideoperiod = MPD.Descendants(ns + "SegmentTimeline").Where(Function(n) n.Parent.Parent.Parent.Attribute("mimeType").Value.Contains("video")).First Dim newaudioperiod = MPD.Descendants(ns + "SegmentTimeline").Where(Function(n) n.Parent.Parent.Parent.Attribute("mimeType").Value.Contains("audio")).First For Each period In MPD.Descendants(ns + "Period").Where(Function(n) n.Attribute("id").Value <> MPD.Descendants(ns + "Period").First.Attribute("id").Value) 'This will copy other video periods to the first period For Each adaptationset In period.Descendants(ns + "AdaptationSet").Where(Function(n) n.Attribute("mimeType").Value.ToString.Contains("video")) For Each s In adaptationset.Descendants(ns + "S") newvideoperiod.Add(New XElement(s)) Next Next 'Do the same for other audio periods For Each adaptationset In period.Descendants(ns + "AdaptationSet").Where(Function(n) n.Attribute("mimeType").Value.ToString.Contains("audio")) For Each s In adaptationset.Descendants(ns + "S") newaudioperiod.Add(New XElement(s)) Next Next Next 'Remove the other periods so we only keep one stream MPD.Descendants(ns + "Period").Where(Function(n) n.Attribute("id").Value <> MPD.Descendants(ns + "Period").First.Attribute("id").Value).Remove 'Save the modified MPD MPD.Save("cleaned.mpd") Return True End Function
This removes all but the highest resolution though, as I don't need anything lower than highest resolution in the MPD. -
Download video from GoPlay (Belgian TV)
By Davy in forum Video Streaming DownloadingReplies: 36Last Post: 10th May 2025, 10:19 -
Need help for download with yt-dlp
By sibhus in forum Video Streaming DownloadingReplies: 26Last Post: 19th Feb 2024, 16:02 -
Download content from GoPlay.be
By roelsmaarten in forum Video Streaming DownloadingReplies: 56Last Post: 13th Feb 2024, 18:01 -
How to download video from goplay.be?
By jessezveneberg in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2023, 19:37 -
Help with YT-dlp batch download
By Loryanam2 in forum Video Streaming DownloadingReplies: 2Last Post: 13th Feb 2023, 16:00
