Has anyone been able to grab master.m3u8 from mtv? I keep getting errors when trying to rip.
But the other m3u8's download but they are the full video with advertisements/commercials & no audio.
They can be free to watch, No sub needed.
Video I am trying to grab (and others from the series).
https://www.mtv.com/episodes/n32ke3/made-ms-ledyard-fair-season-7-ep-11
Code:https://topaz.dai.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/master.m3u8?hdnea=st=1703360788~exp=1703364388~acl=/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/*~id=93700077-491c-41a9-bf1a-202b6a7e2eed~hmac=54f2d93974bba9207d5f970f4b93eb3125c6cd782205189619f94172fc4e6a56&originpath=/ondemand/hls/content/2564872/vid/mgid:arc:episode:mtv.com:97096764-d238-11e1-a549-0026b9414f30/CHS/streams/31dd111f-75f6-49db-bb3c-671fdeb1af28/master.m3u8&CMCD=mtp%3D500%2Cot%3Dm%2Csf%3Dh%2Csid%3D%22ffcd397a-6406-4cc5-b8b9-160f685272a3%22%2Csu
Results 1 to 16 of 16
Console Developper/Network/search m3u8
[Attachment 75785 - Click to enlarge]
you can also use Stream Detector Addon for firefox or Chrome to find directly the link. -
Thanks for the tip but that wasn't really the question I was asking. I do have all that and know how to search m3u and described that already in the first post. The question was, what others were using to download it, On my end the master.m3u8 wasn't downloading, kept erroring. In your screen shot I can see that on my end those m3u8 files are decrypted as index-f2-v1 index-f6-a1 while on my end they are encrypted file names. Is there a different extension I'm missing to see the same thing you are?
My screensays "master.m3u8:hdnea... Your screen says "master.m3u8:MGID..."
Yes, It is the same page and same video. -
you want to know why?
because you dont have ADblocker.
before turn off Ublock origin
[Attachment 75792 - Click to enlarge]
Ublock origin on
[Attachment 75793 - Click to enlarge]
you can now see different -
Thank You, You are correct, I installed the extension and I can see the file names correctly. Indexv1 & indexa1 I can download and combined which is fine, But I was still unable to grab the master.m3u8. Kept getting 404 errors. If anyone has an idea why or something to try I am all ears, If not. No worries and thanks for the help I got so far.
Take a fresh master.m3u8 url and Use N_m3u8DL-RE to download your file.
Code:N_m3u8DL-RE "https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/master.m3u8?mgid=mgid:arc:episode:mtv.com:97096764-d238-11e1-a549-0026b9414f30&ts=1621961836-0&pthash=248dbd7484669503629f1c28df6760e2bac712b0&hdnts=exp=1703654358~acl=/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/*~hmac=7ffe875df451a8f20e630e4c73c50bbf0bc5e8eb281b4252bde7621be6d27e2e&CMCD=mtp%3D500%2Cot%3Dm%2Csf%3Dh%2Csid%3D%22a26d9114-d2ea-48d3-bcde-f1225f729750%22%2Csu" -M format=mp4
normal master.m3u8
i have edit and removed unwanted Resolution keep the higher, and add linkCode:#EXTM3U #EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",NAME="default",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f6-a1.m3u8" #EXT-X-MEDIA:TYPE=SUBTITLES,GROUP-ID="subs0",NAME="British English",LANGUAGE="en",AUTOSELECT=YES,DEFAULT=YES,URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f7.m3u8" #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1011539,RESOLUTION=576x432,FRAME-RATE=29.970,CODECS="avc1.4d401f,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f1-v1.m3u8 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=280960,RESOLUTION=320x240,FRAME-RATE=29.970,CODECS="avc1.4d401e,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f2-v1.m3u8 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=498289,RESOLUTION=480x360,FRAME-RATE=29.970,CODECS="avc1.4d401f,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f3-v1.m3u8 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1450601,RESOLUTION=640x480,FRAME-RATE=29.970,CODECS="avc1.4d401f,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f4-v1.m3u8 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1930342,RESOLUTION=768x576,FRAME-RATE=29.970,CODECS="avc1.4d401f,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f5-v1.m3u8 #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=224786,RESOLUTION=576x432,CODECS="avc1.4d401f",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f1-v1.m3u8?iframes=1" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=62436,RESOLUTION=320x240,CODECS="avc1.4d401e",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f2-v1.m3u8?iframes=1" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=110731,RESOLUTION=480x360,CODECS="avc1.4d401f",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f3-v1.m3u8?iframes=1" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=322356,RESOLUTION=640x480,CODECS="avc1.4d401f",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f4-v1.m3u8?iframes=1" #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=428965,RESOLUTION=768x576,CODECS="avc1.4d401f",URI="hdntl=exp=1703792591~acl=%2f*~data=hdntl~hmac=76fb5679ba2b42822807fbdb5322b0e76ac6c81f0dff3175cca4d5f2fc685c2a/index-f5-v1.m3u8?iframes=1"
because in m3u8, link is not full so will not downloadCode:https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/
m3u8
Code:#EXTM3U #EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio0",NAME="default",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2",URI="https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/hdntl=exp=1703792276~acl=%2f*~data=hdntl~hmac=e2cd5319acb092932aefc5cb35fedc8f8be72dc352262987dfcbdb5ce0f75257/index-f6-a1.m3u8" #EXT-X-MEDIA:TYPE=SUBTITLES,GROUP-ID="subs0",NAME="British English",LANGUAGE="en",AUTOSELECT=YES,DEFAULT=YES,URI="https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/hdntl=exp=1703792276~acl=%2f*~data=hdntl~hmac=e2cd5319acb092932aefc5cb35fedc8f8be72dc352262987dfcbdb5ce0f75257/index-f7.m3u8" #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1930342,RESOLUTION=768x576,FRAME-RATE=29.970,CODECS="avc1.4d401f,mp4a.40.2",AUDIO="audio0",SUBTITLES="subs0" https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/hdntl=exp=1703792276~acl=%2f*~data=hdntl~hmac=e2cd5319acb092932aefc5cb35fedc8f8be72dc352262987dfcbdb5ce0f75257/index-f5-v1.m3u8 #EXT-X-I-FRAME-STREAM-INF:BANDWIDTH=428965,RESOLUTION=768x576,CODECS="avc1.4d401f",URI="https://topaz.viacomcbs.digital/h/a/dG9wYXoxYDk3MDk2NzY0LWQyMzgtMTFlMS1hNTQ5LTAwMjZiOTQxNGYzMGAyNDhkYmQ3NDg0NjY5NTAzNjI5ZjFjMjhkZjY3NjBlMmJhYzcxMmIwYHN3TkFpSHd0UEFZT0hYQVJoTGdBczhpU2RUVmo2S21Sc0pNS05hMXBkRmM/hdntl=exp=1703792276~acl=%2f*~data=hdntl~hmac=e2cd5319acb092932aefc5cb35fedc8f8be72dc352262987dfcbdb5ce0f75257/index-f5-v1.m3u8?iframes=1"
job doneCode:N_m3u8DL-RE -M format=mkv or mp4 "PATH master.m3u8"
I see that, when loading the link in "n_m3u8dl-re", it fails to mux. I wonder if it's missing a key. Normally EMElogger works, but nothing is shown in this case. Just wondering if I was missing something. I understand I can mux with ffmpeg, just quicker to do it all in one if possible.
Grabbing episode streams from This Old House
By eday_2010 in forum Video Streaming DownloadingReplies: 106Last Post: 29th Jul 2024, 10:08 -
help grabbing from Polsat
By zoboomafu in forum Video Streaming DownloadingReplies: 10Last Post: 14th Apr 2024, 07:22 -
need help grabbing pssh
By swappyison in forum Video Streaming DownloadingReplies: 5Last Post: 4th Oct 2023, 04:29 -
Grabbing episode streams from America's Test Kitchen
By eday_2010 in forum Video Streaming DownloadingReplies: 32Last Post: 15th Dec 2020, 08:40 -
grabbing video streams ffmpeg
By lomero in forum Video Streaming DownloadingReplies: 65Last Post: 12th Oct 2019, 09:19
