Results 1 to 12 of 12
  1. I want to burn subtitles to my video, but I want my output to have the same video and audio codecs as well as the subtitles to be exactly like if I enable them in my video player. How do I do that?
    [Attachment 75720 - Click to enlarge]
    [Attachment 75721 - Click to enlarge]
    [Attachment 75722 - Click to enlarge]
    Also, how do I convert an audio track/file into a subtitle track and/or make subtitles out of audio files? I want to end result to look something like this.
    [Attachment 75723 - Click to enlarge]
    Mar 2008
    Look at SubtitleEdit / Whisper (audio to text)
  3. Originally Posted by davexnet View Post
    What's Whisper? How will that help? Can you send me the link?
    Mar 2021
    Israel
    Install latest SubtitlesEdit
    Top menu: Video > Audio to Text (Whisper)
    There are several option, try default first.
    Mar 2008
    Download SubtitleEdit, load the video, you'll find the option under the "video" menu at the top
  6. Originally Posted by Subtitles View Post
    What's the default for Whisper? Which model for it should I choose? Also, how do I make sure the subtitles of the output match those for the input?
    Here's the subtitle track if you need it.
    https://files.videohelp.com/u/308613/kk.srt
    Mar 2021
    Israel
    Whisper will create new subtitles file for you based on the audio. It has nothing to do with the subtitles file that you attached.
  8. Originally Posted by Subtitles View Post
    I meant for burning it in for the video. Here are the settings.
    [Attachment 75730 - Click to enlarge]
    [Attachment 75731 - Click to enlarge]
  9. I have a video with a subtitle track, but I want to burn them into the video without having to extract the subtitles themselves. How do I do that?
  10. I'm a Super Moderator johns0's Avatar
    canada
    Load the video into vidcoder and click on the subtitle track and then click on the burn in option.
  11. Originally Posted by johns0 View Post
    What about HandBrake?
  12. I'm a Super Moderator johns0's Avatar
    canada
    It will do the same.
