i want'ed to know what kind of file submux use ??
before the convert and after it ???
2. the file that submux does, how can i burn it, with an mpeg file
to create a svcd movie with selected subtittle ???
10x in advance
For submux input and output is an mpg file.
Your subtitles need to be in the Philips SVCD Designer format and must be 8 bit. If your source is a dvd then you can use SubRip to create your subtitles. You will have a bunch of .bmps and one .sub file which lists the times of each sub.
The resulting subbed mpg that submux can be burned like any other svcd compliant mpg. Simply read here: http://www.vcdhelp.com/author.htm and choose which method works best for you.
BTW all this info is clearly wriiten in Submux's readme. Always read the documentation on a program before asking questions about it.
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Unable to run VobSub (SubResync or Submux)
By DeathStalker77 in forum SubtitleReplies: 1Last Post: 16th Sep 2009, 17:07 -
SubMux ~ DVDplayer problem
By Sir Liam in forum SubtitleReplies: 3Last Post: 17th Oct 2008, 07:10 -
Winsubmux error. Plus submux not muxing
By Codecoder in forum Authoring (VCD/SVCD)Replies: 1Last Post: 12th Jul 2008, 22:30 -
submux output avi file no sound on standalone DVD player
By sigmma in forum SubtitleReplies: 2Last Post: 24th May 2007, 05:19
