Drug my old amscope mu300 out yesterday and found I couldn't use it.
Win10 cannot see it at all. Not itself nor with Amscope software which otherwise install and runs fine.
On Linux mint the software would not even install.
I found on Mint that the camera is seen by lsusb so that much is good.
But cheese cannot see it nor can guvcview. it does not have an entry in /dev/video.
I've emailed Amscope but I think they're on Xmas holiday. Anyone got any ideas I could use perhaps?
If the device is working and the cable is good, Windows 10 should at least acknowledge a device
when the USB is plugged in.
Have you looked in the device manager? -
So I just took a look and it sees a device but reports no drivers loaded and can't find any. The software has been installed though, as I think I said.
So I checked for drivers and amscope's site was a bit strange. had images that didn't show. that kind of thing. seemed to have only one software required which is the one I've installed. but there was one place where it said you'd need directshow and twain. so i installed both of them.
It didn't help. I think directshow in particular is not supported on win10. when amscope gets back to me - after xmas I guess - then I'll know but I'm thinking the thing isn't going to work with win10.
that's alright. I can put up a win7 box if I have to. -
There is one other possibilty I'm aware of, check the setting at settings/privacy/camera
for linux mint, see this thread here - https://forums.linuxmint.com/viewtopic.php?t=245147
and here - https://amscope.com/pages/software-downloadsLast edited by october262; 24th Dec 2023 at 23:49.
MX-23.1 vs LINUX 21.2 MINT MATE
By cornemuse in forum ComputerReplies: 5Last Post: 22nd Nov 2023, 00:27 -
How do I run BDSuptosub on Win10?
By thermalzombie in forum SubtitleReplies: 1Last Post: 6th Oct 2023, 07:55 -
Win10 1511 help
By cysjunk in forum Capturing and VCRReplies: 7Last Post: 12th Feb 2022, 14:37 -
[LINUX] can ffmpeg (or any othe linux command) genere an ANIMATED waveform
By Jintor_Universe in forum ProgrammingReplies: 5Last Post: 28th Oct 2021, 20:29 -
How to capture HDMI Video using Linux Mint
By Palladini in forum Capturing and VCRReplies: 2Last Post: 24th Apr 2019, 20:25
