Is AviSynth RIFE and VapourSynth RIFE the same thing? Does that mean FlowFlames is a GUI for both?
Also, I use it to make a video and gif that goes above 60fps and I want to remove any extra (or regular) frames to set the frame rate to that amount. How do I do that?
Basically: Yes, but the releases may support different model versions.Is AviSynth RIFE and VapourSynth RIFE the same thing?
No. Afaik FlowFlames does not use Avisynth or Vapoursynth, but uses https://github.com/hzwer/Practical-RIFE directly.Does that mean FlowFlames is a GUI for both?
Depending on the RIFE implementation and model you use, you can set a target frame rate.Also, I use it to make a video and gif that goes above 60fps and I want to remove any extra (or regular) frames to set the frame rate to that amount. How do I do that?
You could also use ChangeFPS.users currently on my ignore list: deadrats, Stears555, marcorocchini
Converting 60fps to 25fps and removing duplicate frames
By rgr in forum Video ConversionReplies: 2Last Post: 30th Sep 2022, 06:34 -
Removing I-frames programmatically (automatic workflow)
By vanjavk in forum EditingReplies: 5Last Post: 11th Dec 2021, 03:38 -
Removing all duplicate frames in a video clip
By ecortez in forum EditingReplies: 0Last Post: 10th Mar 2021, 20:23 -
Removing blended frames that are interlaced
By Dutchsteammachine in forum RestorationReplies: 5Last Post: 28th Aug 2020, 16:33 -
Removing frames?
By Chauceratemyhamster in forum EditingReplies: 12Last Post: 4th Jul 2020, 14:42
