I have a homemade DVD-RW disc that I created few years ago. I can't remember which DVD burner I used but it could have been a Pioneer model that doesn't work anymore. There is still about 1 hour of available space on it (made a note on a label) and this is why I didn't finalize it at the time.
I am using today an external DVD burner but it doesn't load the disc.
I tried few software like Nero Video, Nero Recode, Nero Rescue without luck. Only Isobuster seems to be able to recover it but it is not worth it to pay for the license.
I could just format the disc and forget about it as the content is probably not worth the trouble, but I have several unfinalized discs and I would like to find a cheap solution for this.
Thanks for recommendations.
You could try the last free version
https://securedl.cdn.chip.de/downloads/11757572/IsoBuster_0.99.9.zip -
You need a vmd like this:
https://github.com/otya128/winevdm/releases/download/v0.9.0/otvdm-v0.9.0.zip
to run 16 bit applications on Windows 64bit.
Read more here:
https://techcommunity.microsoft.com/t5/modern-work-app-consult-blog/running-16-bit-app...t/ba-p/1671418 -
I remembered that those unfinalized DVD's were recorded using a standalone DVD recorder that has 160GB HDD. The model is Pioneer DVR-540H-S.
I stopped using it many years ago and today I hooked it up to my TV. The remote buttons are all sticky and hard to navigate.
I will look for a replacement remote controller or try to clean the buttons which is not going to be an easy task.
Anyway I managed to finalize few DVD's and then I will copy to the PC HDD and format the DVD-RW or throw away the DVD-R discs.
It served me well during those years until the cost of HDD's came down, making recording to DVD's less attractive.
Just think about it. A WD MyPassport 5TB the size of my palm can hold over 1000 DVD discs.
I wonder what we will have 10 years from today. -
The Pioneer recorder video output doesn't look so good on my TV screen. I am using SCART-SCART cable.
I have also Components output and Component Input on the TV but I don't have a component cable. Would it make much difference if I buy one?
The remote buttons are really bad. I ordered a replacement which might take about a month to arrive.
how to rip a dvd and blu ray disc without a pc or mac can it be done
By barry25 in forum DVD RippingReplies: 7Last Post: 9th Jul 2023, 18:42 -
Difference in quality between MKV rip and original disc?
By Guphanti in forum Blu-ray RippingReplies: 5Last Post: 23rd Aug 2022, 02:23 -
Ripping unfinalized home DVD
By hkcj in forum DVD RippingReplies: 6Last Post: 8th Sep 2021, 03:13 -
help needed can i rip a disc or extract the video files like in the 1st pic
By elm in forum EditingReplies: 1Last Post: 16th Mar 2020, 04:11 -
Proper way to rip Blu-ray full disc and movie?
By davevid in forum Blu-ray RippingReplies: 1Last Post: 5th May 2019, 01:57
