    Nov 2023
    USA
    hello,
    every time I try to retrieve a video from m6. I have a problem every time I try to enter the headers.
    for example :
    pour https://www.6play.fr/le-nouveau-p_25032/partie-1-c_13045310
    here is the data retrieved:
    PSSH:
    AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQNP JRpRQYw87uT+LRQwkNmCIkZXlKaGMzTmxkRWxrSWpvaVkyeHBj Rjh4TXpBME5UTXhNQ0o5
    License:
    https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
    Headers:
    {'X-dt-auth-token':
    'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzUxMiJ9. eyJvcHREYXRhIjoie1widXNlcklkXCI6XCIzZTIwOTkyOGY0ZT I0N2FlYmRkNWY5YTg2OTNjNjExYVwiLFwibWVyY2hhbnRcIjpc Im02XCIsXCJzZXNzaW9uSWRcIjpcIm02cmVwbGF5XCJ9IiwiY3 J0IjoiW3tcImFjY291bnRpbmdJZFwiOlwiXCIsXCJhc3NldElk XCI6XCJjbGlwXzEzMDQ1MzEwXCIsXCJwcm9maWxlXCI6e1wicH VyY2hhc2VcIjp7fX0sXCJvdXRwdXRQcm90ZWN0aW9uXCI6e1wi ZGlnaXRhbFwiOmZhbHNlLFwiYW5hbG9ndWVcIjpmYWxzZSxcIm VuZm9yY2VcIjpmYWxzZX0sXCJvcFwiOntcImNvbmZpZ1wiOntc IkhEXCI6e1wiUGxheVJlYWR5XCI6e1wibWluU0xcIjozMDAwLF wiYW5hbG9nVmlkZW9PUExcIjoyMDAsXCJjb21wcmVzc2VkRGln aXRhbFZpZGVvT1BMXCI6NTAwLFwidW5jb21wcmVzc2VkRGlnaX RhbFZpZGVvT1BMXCI6MzAwfSxcIldpZGV2aW5lTVwiOntcIm1p blNMXCI6NSxcInJlcXVpcmVIRENQXCI6XCJIRENQX1YxXCJ9fS xcIlNEXCI6e1wiUGxheVJlYWR5XCI6e1wibWluU0xcIjoyMDAw LFwiYW5hbG9nVmlkZW9PUExcIjoyMDAsXCJjb21wcmVzc2VkRG lnaXRhbFZpZGVvT1BMXCI6NTAwLFwidW5jb21wcmVzc2VkRGln aXRhbFZpZGVvT1BMXCI6MjUwfSxcIldpZGV2aW5lTVwiOntcIm 1pblNMXCI6MSxcInJlcXVpcmVIRENQXCI6XCJIRENQX05PTkVc In19LFwiVklERU9fQVVESU9cIjp7XCJQbGF5UmVhZHlcIjp7XC JtaW5TTFwiOjIwMDAsXCJhbmFsb2dWaWRlb09QTFwiOjIwMCxc ImNvbXByZXNzZWREaWdpdGFs VQqz1Cy7R8c9ckYpA_pWzn9vOk49ivSyJwsBcPfr4JFLMarXB2 Wz3Rq5SyByWvLyCwLkN-7xqGphqXAYg26_Iw'}
    I have an error: ERROR
    'ascii' codec can't encode character '\u2018' in position 0: ordinal not in range(128)
    thanks
  2. use chrome to copy token, if you use Firefox, must carefully, maybe blank/space or an Enter in token when you copy it.
  3. 6play.fr token lifespan is very very short.
    Le nouveau : Partie 1:
    --key 34f251a51418c3ceee4fe2d143090d98:6f34b94359d6dee933bcb9d95b76c9c7
    Le nouveau : Partie 2:
    --key 56affc9cc4fcf4474a79a09025f692df:37c80ee55856f3899fa62475317ba5cc
    Nov 2023
    USA
    I use chromium.
    Nov 2023
    USA
    between Chromium and chrome, there's a difference in the header. i think that's where the error is coming from.
  6. Originally Posted by ludo View Post
    \u2018 is just an ' - in position 0. So it seems that the very first character in your header is wrong. I suppose the problem is just, that you have some spaces and a carriage return between
    {'X-dt-auth-token':
    and
    'eyJ0eXAiO
    So try with header:
    {'X-dt-auth-token':'eyJ0eXAiO.......
    Nov 2023
    USA
    I had tried but I had the same problem for chromium whereas when I did it with Chrome, I had no problem.
  8. Then Chromium seems to copy a wrong type of the sign: '
    There are several different kinds, and this often leads to problems in interpreting. Interesting, that Chrome does it correctly, and Chromium don't.
