On the left side of the video there is a keyboard that has some ventilation grills on the back of it. The grills in the image are very small so I believe QTGMC is deinterlacing the grill. I've included two videos, interlaced and deinterlaced, so it makes sense. It's causing some diagonal lines that are buzzing. Is there anything I can do, filter wise, to avoid this?
Try
Code:ffms2("interlaced clip.mkv") #or your source filter AssumeBFF() BWDIF(field=2,thr=0.8) #adjust the thr QTGMC(InputType=2) #for cleaning up
Removing Color Banding (Moire Pattern?)
By meeshu in forum EditingReplies: 25Last Post: 2nd May 2023, 12:27 -
Handling moire?
By Selur in forum Newbie / General discussionsReplies: 4Last Post: 26th Feb 2022, 11:10 -
Color moire/flickering in PAL footage
By voyagerhelp in forum Video ConversionReplies: 5Last Post: 9th Jan 2021, 23:17 -
Reducing Moiré Effect
By ZetaStax in forum RestorationReplies: 8Last Post: 18th Feb 2020, 10:19 -
what effect is this effect?
By ricmetal in forum EditingReplies: 14Last Post: 15th Feb 2019, 09:48
