There is a video with errors during broadcast and the deinterlacing generated these kind of jarring green artifacts. How to make them let's say black?
SpotLess and similar filters might be able to remove those artifacts if they are only in a few frames.
BasicVSR++ might also be able to help.users currently on my ignore list: deadrats, Stears555, marcorocchini -
That sort of corruption tends to run the full length of the GOP, and thus hard to remove.
edit ... is that Chloe Bennett?Last edited by lordsmurf; 27th Dec 2023 at 20:46.
To make it black or some other color you can chroma key or use maskhs in avisynth . The problem with that approach is if you have wanted green objects (e.g plant leaves) - they will be affected too. You might limit it with other techniques such as other masks depending on the distribution of artifacts
AviSynth QTGMC to fix interlacing artifacts on progressive video.
By Sandfly in forum RestorationReplies: 22Last Post: 9th May 2023, 21:40 -
Kind of green tint while encoding sd with 10bit depth (staxrip)
By feynek in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2023, 00:56 -
Help getting rid of jagged/pixelated edge artifacts from DVD rip
By sebastiandm in forum DVD RippingReplies: 4Last Post: 21st Apr 2020, 17:33 -
Capturing Hi8 tape using VirtualDub and Avisynth. Artifacts showing.
By MBX in forum Capturing and VCRReplies: 4Last Post: 18th Dec 2019, 04:37 -
avisynth 50p to 50i: how to avoid the flickering artifacts?
By marcorocchini in forum Newbie / General discussionsReplies: 15Last Post: 20th Jul 2019, 10:58
