Shoul I be using another type of filter other than antialiasing to repair this?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Downscaling to the original resolution, filtering then properly upscaling might also work in some cases. Probably not here since the upscaling factor is too high in relation to the noise&co and overall quality. (Sometimes using QTGMC mode > 0 also can help, but not with such strong aliasing.)
Machine learning filters that do general restoration filtering might also be able to help, but will be slow.
Removing aliasing artifacts seems what anti-aliasing filters are made for, so what is wrong using them?
Since you mentioned Santiag, what settings did you use to get rid of those aliasing artifacts? (I doubt the default values will work)
Cu Selurusers currently on my ignore list: deadrats, Stears555 -
i am embarking on converting over 1000 dvd from a variety of sources, good bad and indifferent picture quality and am astounded at what handbrake can do,especially if left alone and not filtered too much, also my 14 year old sony 1080p non smart tv and its filters. Conclusion , less is more.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Thanks, and sorry for the delay in response. I tried using the santiag filter as follows but it's not doing much:
HTML Code:santiag(strh=3, strv=3, type="nnedi3", nns=1, nsize=6, aa=48, aac=0, scaler_post="Spline36Resize")
HTML Code:BicubicResize(640, 480) santiag(strh=2, strv=2, type="nnedi3", nns=1, nsize=6, aa=48, aac=0, scaler_post="Spline36Resize")
Are there any suggestions you would recommend I learn?
It's not interlaced, but if you separate the fields, one field is quite a bit worse than the other.
Perhaps this can be used to devise a strategy:
Code:LWLibAvVideoSource("c:\users\davex\downloads\Christmas shopping in 1988.mp4").trim(140,0) separatefields() selecteven()
Please help me to repair this mp4 video
By flashandpan007 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jan 2022, 14:30 -
MP4 repair (AAC audio repair)
By holger123 in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2020, 17:47 -
Video Repair
By niteghost in forum Newbie / General discussionsReplies: 0Last Post: 16th Apr 2020, 16:36 -
AviSynth and Santiag to make an anti-aliased video
By Alkimical in forum RestorationReplies: 1Last Post: 25th Jan 2020, 13:43 -
Is there a code for santiag in Staxrip with avisinth+ ?
By SomeoneNeutral in forum RestorationReplies: 4Last Post: 4th Sep 2019, 12:11
