Hey there I'm looking to burn a few downloaded movies which are out of print onto a Verbatim DVD+R DL disc which claims to have a maximum capacity of 8.5 GB and 240 minutes.
Does anyone know what will happen if I try to fit say three or four films onto one disc but the total VOB size is still less than 8.5GB but the total minutes exceed 240?
I normally convert the mp4 or mkv files to VOB using winxdvd author and then create the menu using dvdstyler and burn using imgburn. It seems like dvdstyler will allow me to create the dvd as long as the VOB files combined are below 8.5GB but doesn't seem to care about exceeding 240 minutes!
Does anyone know if there will a major loss of picture or sound quality if I burn these to a disc?
Any help would be appreciated from anyone thats attempted to do this themselves in the past. Thanks!
It's all a Q. of bitrate. The lower the bitrate to squeeze more playback time the lower the potential quality.
Take a single-sided disk which claims 2 hours of recording/playback. That, itself, can equate to an approx 4000 kbps bitrate which, itself, is not an exact figure since it depends also on the audio. Increase the playback time will reduce the bitrate and quality. Audio quality does not change since that is fixed.
I have always used a simple formula for a single-sided disk. 1 hour * 8000 kbps. 90 mins * 6000 kbps. 120 mins * 4000 kbps. Anything more and you are asking for trouble (unless you go down to half D1 which will affect playback enjoyment especially on larger screens) -
Also to mention: DVD+R DL have 7,91GB real capacity, Single Layer 4,38GB
In my experience SL-DVD are more reliable than DL-DVD -
You'll have to forgive me as I'm a newbie so are you saying that if I take say three seperate film VOB's and put them into dvdstyler to create the menu and DVD and the three films combined come to roughly 270 minutes in length that dvdstyler will automatically lower the bitrate and downgrade the picture quality from the orginal VOB files?
In that case is it best to stick to only putting two 120 minutes movies onto one dual layer DVD? -
Firstly, I do not think that dvdstyler can re-process VOBs. One dvd will have several VOBs each of .99 gb. You could, however, convert those VOBs to mpeg using vob2mpeg and then import these into dvdstyler
Then, let's say fo argument sake that the original dvd filled a 4 gb single-sided disk. So three could well equate to 12 gb. 12 into 8 will not go so there must be a reduction in bitrate to compensate.
Well if those two 120 minute movies are only on single-layer disks then, yes. You have to inspect the actual disk to see just how many vobs there are since commercial disks are rarely single-sided @ 120 mins. So there is still potential reduction in bitrate. -
FFV1 - FFmpeg LossLess Encoder Maximum Quality Settings
By Tom4 in forum Video ConversionReplies: 7Last Post: 10th May 2023, 02:32 -
will there be quality loss
By cns00 in forum Video ConversionReplies: 4Last Post: 2nd Sep 2022, 13:23 -
Deinterlacing DVD source while preserving the maximum quality possible.
By dopethrone in forum Newbie / General discussionsReplies: 24Last Post: 19th Feb 2022, 23:54 -
DVD Convert without quality of loss (.AVI? increase bitrate from original?)
By MwBakker in forum Newbie / General discussionsReplies: 37Last Post: 29th May 2020, 06:34 -
Re-encoding DV to DV - quality loss?
By Xoanon in forum RestorationReplies: 9Last Post: 22nd Jul 2019, 08:30
