Hi
can anyone help to figure out i am stuck and not undertand why ist not work kid to pssh
also the link its
https://cdn.bitmovin.com/content/assets/art-of-motion_drm/mpds/11331.mpd
License URL: https://cwip-shaka-proxy.appspot.com/no_auth
the defualt kid its
eb676abbcb345e96bbcf616630f1a3da
its standing in mpd file and see same with init mp4 same kid thad ok
so if i calculate the kid to pssh
import base64
def get_pssh(keyId):
array_of_bytes = bytearray(b'\x00\x00\x002pssh\x00\x00\x00\x00')
array_of_bytes.extend(bytes.fromhex("edef8ba979d64 acea3c827dcd51d21ed"))
array_of_bytes.extend(b'\x00\x00\x00\x12\x12\x10')
array_of_bytes.extend(bytes.fromhex(keyId.replace( "-", "")))
return base64.b64encode(bytes.fromhex(array_of_bytes.hex( )))
kid = input("Please input KID : ")
kid = kid.replace(' ', '')
kid = kid.replace('-', '')
assert len(kid) == 32 and not isinstance(kid, bytes), "wrong KID length"
print("PSSH {}".format(get_pssh(kid).decode('utf-8')))
its calculate wrong pssh
example its calculate
pssh : AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEOtnar vLNF6Wu89hZjDxo9o=
bud thad will not work get b'INVALID_REQUEST'
bud if i use the pssh from mpd file
AAAAW3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADsIARIQ62 dqu8s0Xpa7z2FmMPGj2hoNd2lkZXZpbmVfdGVzdCIQZmtqM2xq YVNkZmFsa3IzaioCSEQyAA==
--key ccbf5fb4c2965be7aa130ffb3ba9fd73:9cc0c92044cb1d694 33f5f5839a159df
--key 9bf0e9cf0d7b55aeb4b289a63bab8610:90f52fd8ca48717b2 1d0c2fed7a12ae1
--key eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4 589152b57d2dacb
--key 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def6 14227b9c0f03e26
--key 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e2030 04b30c4eaf348f4
get the keys
what is wrong or how can be coreckted this can can budy help me to understand this stration ?
kind regarts
KID: eb676abbcb345e96bbcf616630f1a3da
PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEOtnar vLNF6Wu89hZjDxo9pI49yVmwY=
My KID to PSSH output above
from Cached data -
The pssh string contains many fields that identify the media content. The generic kid to pssh scripts cannot work out all the fields. The media provider identity is not in the kid but it 'may' be in the pssh.
Most sites do not check all the pssh fields so a short form pssh will work - unfortunately for you - your site checks everything it would appear.
The only way around that is to use a tool to download and search the init.mp4 (usually audio) and find the pssh therein.
There was a script posted a while back to do this.
[Attachment 75695 - Click to enlarge]Last edited by A_n_g_e_l_a; 23rd Dec 2023 at 07:30.
Noob Starter Pack. Just download any Widevine media! Over 26,500 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
big big thanks angela for your help its works
Code:import requests import base64 import subprocess import os import glob import shutil def find_wv_pssh_offsets(raw: bytes) -> list: print('Searching pssh offsets') offsets = [] offset = 0 while True: offset = raw.find(b'pssh', offset) if offset == -1: break size = int.from_bytes(raw[offset-4:offset], byteorder='big') pssh_offset = offset - 4 offsets.append(raw[pssh_offset:pssh_offset+size]) offset += size return offsets def to_pssh(content: bytes) -> list: wv_offsets = find_wv_pssh_offsets(content) return [base64.b64encode(wv_offset).decode() for wv_offset in wv_offsets] def from_file(file_path: str) -> list: print('Extracting PSSHs from init file:', file_path) return to_pssh(open(file_path, 'rb').read()) def generate_init_mp4(url: str): print('Generating init.mp4 using direct MP4 URL...') response = requests.get(url, stream=True) if response.status_code == 200: with open('init.mp4', 'wb') as out_file: shutil.copyfileobj(response.raw, out_file) else: print('Failed to download file. Status code:', response.status_code) return None return 'init.mp4' def find_and_process_mp4(): mp4_files = glob.glob('*.mp4') if mp4_files: for mp4_file in mp4_files: pssh_list = from_file(mp4_file) target_pssh = None for pssh in pssh_list: if 70 < len(pssh) < 190: target_pssh = pssh break # Stop searching once a suitable PSSH is found if target_pssh: print(f'\n{target_pssh}\n') with open("pssh.txt", "w") as file: print(target_pssh, file=file) return print('No suitable PSSH found in any MP4 files.') else: print('No MP4 files found in the current directory.') def from_url_or_file(): user_input = input('Please press Enter to search for *.mp4 files or provide the URL: ') if user_input.startswith(('http://', 'https://')): if user_input.endswith('.mpd'): print('MPD URL detected. Generating init.mp4 using yt-dlp...') subprocess.run(['yt-dlp', '--allow-u', '--no-progress', '--console-title', '--output', 'init.mp4', user_input], stdout=subprocess.DEVNULL, stderr=subprocess.STDOUT) find_and_process_mp4() else: generated_file = generate_init_mp4(user_input) if generated_file: find_and_process_mp4() else: # User pressed Enter, search for *.mp4 files find_and_process_mp4() from_url_or_file()
How can I generate pssh if no kid in manifest?
By Musito in forum Video Streaming DownloadingReplies: 11Last Post: 7th Feb 2024, 12:27 -
What the kid or pssh from this mpd?
By hannc in forum Video Streaming DownloadingReplies: 3Last Post: 18th Dec 2023, 15:43 -
Instructions to extract key : kid by pssh
By vuitv in forum Video Streaming DownloadingReplies: 8Last Post: 29th Apr 2023, 10:53 -
Mpd Kid pssh how do I download it?
By cinamews in forum Video Streaming DownloadingReplies: 9Last Post: 24th Oct 2022, 12:20 -
how to generate pssh for this kid?
By tomtom12 in forum Video Streaming DownloadingReplies: 3Last Post: 24th Oct 2022, 04:49
