If I try to play a video-only mkv (AVC, no audio) via thumbdrive, the video content doesn't display on the TV. The player's info popup indicates it's playing (timer running). If I mux any kind of audio to the video, it will display, but the videos didn't originally have audio, so I'd rather not have to compensate. Older LG BD611 blu-ray player.
Would muxing a silent audio track with the video to create a new MKV be an acceptable solution?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
The question is how to play it without adding a superfluous audio track. One of the silent videos on the bluray (m2ts file) is mpeg2, and that plays normally when ripped from the disc, but if it were originally h264, I don't know if it would play normally.
H.264 is compatible with the M2TS container file format. You could try remuxing the problem MKV file to an M2TS file with TSMuxerGUI. If that succeeds, then try playing it as an experiment.
I wouldn't have thought the container mattered, but I tried it (with a different video-only file) and it worked. One of the original blu-ray files in MKV also played...
I'm using MeGUI to re-encode, and usually mux the new encode with new audio encode in Mkvtoolnix. Without any audio, there was no reason to mux just a video file, but as it turns out, doing that "fixes" the MKV so it will play. I've tried Mkvtoolnix to smooth out issues (not usually successfully), but for some reason it didn't occur to me with this one.
Thank you for your suggestion which ultimately led me to a solution.
VirtualDub2 - Display video pane on a secondary display?
By simple in forum Video ConversionReplies: 0Last Post: 17th Sep 2021, 13:54 -
Files that won't display their correct aspect ratio on blu-ray player
By Nico Darko in forum Video ConversionReplies: 12Last Post: 6th Feb 2021, 15:22 -
MKV Video shrinked and to Blu-Ray 25
By Spovkobob in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jul 2020, 05:36 -
How to burn a blu-ray video disc using MKV files with these specs?
By robertazimmerman in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Apr 2019, 23:14 -
Video file won't display properly in Subtitle Edit
By kasfig in forum SubtitleReplies: 2Last Post: 4th Jan 2019, 06:16
