Hi to all, I wait for a help for necessary keys I need to decode this RTLPlay video.
Here is the StreamFab results I give you:
To
Code:PSSH value: AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQgBzp6ahalYEhPmy+bI/LdyIkZXlKaGMzTmxkRWxrSWpvaVkyeHBjRjh4TXpBME16a3lOeUo5Code:KID: 801ce9e9a85a9581213e6cbe6c8fcb77
What’s the keys, please?
If StreamFab do the work, he need 50h to finish all. A long time, that’s why I need to have these keys.
Thanks to tell me more…
Results 1 to 11 of 11
im getting like this...
[Attachment 75621 - Click to enlarge]
my pc have turn off adblocker :/ -
--key 801ce9e9a85a9581213e6cbe6c8fcb77:3e2c59a9c5ba8eeea107053c7035737d
[Attachment 75623 - Click to enlarge] -
Thanks a lot, "CrymanChen".
To conclude, with a Windows computer, to download and decrypt this specific video, I’ll use the « .\N_m3u8DL-RE » commands. But what’s the correct entry with we already know ?
Like this, is it correct?
Code:.\N_m3u8DL-RE --key 801ce9e9a85a9581213e6cbe6c8fcb77:3e2c59a9c5ba8eeea107053c7035737d "https://rtlbe.vod.6cloud.fr/rtl.be/output/7/b/e/7beda61f8b5cd6033bc50a617d641655794eb300/static/13043927_114de74c5ff0c6b81eca2d1c51db4727_web_dash_upTo540p_540p_vbr_cae_drm_software.mpd" -M format=mp4
Code:.\ N_m3u8DL-RE --key 801ce9e9a85a9581213e6cbe6c8fcb77:3e2c59a9c5ba8eeea107053c7035737d "https://rtlbe.vod.6cloud.fr/rtl.be/output/7/b/e/7beda61f8b5cd6033bc50a617d641655794eb300/static/13043927_114de74c5ff0c6b81eca2d1c51db4727_web_dash_upTo540p_540p_vbr_cae_drm_software.mpd" -M format=mp4
just add savename if you want
Code:N_m3u8DL-RE -M format=mkv --key 801ce9e9a85a9581213e6cbe6c8fcb77:3e2c59a9c5ba8eeea107053c7035737d "https://rtlbe.vod.6cloud.fr/rtl.be/output/7/b/e/7beda61f8b5cd6033bc50a617d641655794eb300/static/13043927_114de74c5ff0c6b81eca2d1c51db4727_web_dash_upTo540p_540p_vbr_cae_drm_software.mpd" --save-name video
Thanks CrymanChen ! I optained a succesfull decrypted video with you and N_m3u8DL-RE.
I have an interesting question
Code:My Lic is https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
Code:Yours is: https://lic.drmtoday.com/license-proxy-widevine/cenc/
is my "Lic html" bad ?
If i read here,HTML Code:https://forum.videohelp.com/threads/408665-rtlplay-be
it's a rule: when you have 'lic.drmtoday.com' use on l3.py
Code:https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
what happend? ElCap ever said parameters "?specConform=true" force the license server turn back raw response, without "?specConform=true" return json response. that is the only difference, key same. if that is l3.py , must modified to parse json response, or that is not l3.py.
how they find this parameters, i dont know too, lol. -
Sorry for being away (was just dealing with some stuff tonight).
@GilbertA83: Like this, is it correct?
And as for your reply in #7... I'm sorry I didn't catch your words. Would you mind elaborating your questions please...
But to try answering your question... I couldn't say that 'your lic url' is bad.
As I could remember, during the year 2022 and January 2023, we have to add the '?specConform=true', and at that time, the license server will only return the license in base64 format.
But after a change in their DRM system, as you can see, the license server will return a JSON object, in which the license lies, adding '?specConform=true' is not necessary anymore. And thus I made some changes to l3mubi.py Line #77
And it's noteworthy that, although there are several sites using the same DRM system (lic.drmtoday.com), different params in the headers are needed.
For example, in mubi.com, only dt-custom-data is needed, but in your mentioned site rtlplay.be, you need x-dt-auth-token. So I would regard this as the answer of your question about 'it seems a correct RTLPlay Lic entry different of yours...'
when you are trying to get the content keys, you can try both adding '?specConform=true' or not adding it to see the result. That's one little tip.
Above are my own discoveries, please make it full if there are something that I left. Thanks. -
Help needed with WKS-KEYS on a free website
By tjvatikaki in forum Video Streaming DownloadingReplies: 8Last Post: 7th Feb 2025, 03:19 -
By tjvatikaki in forum Video Streaming DownloadingReplies: 14Last Post: 5th May 2024, 13:25 -
Download from 6play or rtlplay
By Night18 in forum Video Streaming DownloadingReplies: 7Last Post: 19th Apr 2024, 13:10 -
rtlplay.be
By mohegan in forum Video Streaming DownloadingReplies: 5Last Post: 19th Dec 2023, 12:04 -
wks-keys or TPD-Keys cmd.exe errors
By euphonic in forum Video Streaming DownloadingReplies: 1Last Post: 25th Jun 2023, 14:24
