Hi Guys
My very first post. I'm using VidCoder having moved on from Handbrake.
I use MakeMKV to create uncompressed mkv then use VidCoder to compress to H.264 mkv and have a lot of files to process.
The problem is that whilst I can set the subtitle selection for a single mkv and add it to the batch que there seems to be no way to apply this to the entire batch que. VidCoder custom H.264 settings does allow its settings to be applied to the entire batch que but alas there seems to be no way to set subtiles within the custom encoder itself.
Do I really have to set subtitles for each mkv before I add it to the batch que![]()
Results 1 to 1 of 1
How do I convert MKV to MP4 in batch with burned-in subs? (Vidcoder)
By fighuass in forum Video ConversionReplies: 12Last Post: 29th Aug 2021, 12:02 -
How to configure mpc-hc external subtitle selection
By snh in forum SubtitleReplies: 2Last Post: 19th Aug 2021, 05:02 -
Magix batch conversion applying letterbox to video
By stantheman1976 in forum Video ConversionReplies: 4Last Post: 13th Jan 2021, 16:20 -
applying a filter to a batch in tmpg mastering works 5
By devdev in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2019, 10:49 -
Find and replace only in selection, Subtitle Edit
By SUWII in forum SubtitleReplies: 6Last Post: 21st Dec 2018, 02:14
