For just the directshow filters, LAV filters is probably a better choice.
VLC does not use the system codecs. It plays almost everything using its internal decoding.
For any file it does not play, you should look at the file details (codec info,etc)
using mediainfoLast edited by davexnet; 18th Dec 2023 at 16:34.
Some codec packs contain ad-wares and some codec packs are specificly put together to, when combined have an increased risk of malfunction or cause errors or security weakness together with other programs or settings, might not happen very often but it have happend, while some other codec pack are completely fine to use!
Allso if an specific codec would give an error message or for example be rejected by youtube for it is something wrong with it is common for peopole to put theese codecs into packs and share them in hope of ruin an complete collection of movies/videos intended for uploading to youtube, or to ruin it for any other possible scenario that it could function well at first glimce, but later on when finally it is time to shine, it is something wrong with it such as laggs, stutters, faulty pixels and more!
Edit: If it is an original codec with installation setup, it come along the creators brand/mark on the installation with some additional info about the codec, seem a bit more relaible, maybe better to download and install them separately as it is easier to destuingish if it is the real codec one is acctualy looking to install! If lucky then allso it come along an possibilty to get free support if there would be an complete disaster when all videos is something wrong with them! Maybe K-Lite offers theese things allso, i dont know!Last edited by Swedaniel; 18th Dec 2023 at 16:39.
I don't need/use/install codec packs.
Configuring K-lite Codec Pack for DAWs
By Bencuri in forum AudioReplies: 1Last Post: 22nd Jun 2022, 12:19 -
k-lite codec pack 16.8.7 - MPC-HC - LAV Filters - (HDMV PGS) .sup
By maudit in forum SubtitleReplies: 0Last Post: 4th Mar 2022, 09:34 -
Best codec packs for encoding/decoding bluray movies?
By WAusJackBauer in forum Blu-ray RippingReplies: 4Last Post: 17th Jun 2021, 18:19 -
Bulk translation tool?
By jooj in forum SubtitleReplies: 0Last Post: 1st Nov 2020, 09:36 -
Vegas 13: How do I know how many frames I've selected?
By vegas13 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2020, 21:45
