Results 1 to 16 of 16
  1. Using ffmpeg this command "ffmpeg -i file -c copy file"
    But the output file is always OOS
     libavutil      58. 14.100 / 58. 14.100
      libavcodec     60. 22.100 / 60. 22.100
      libavformat    60. 10.100 / 60. 10.100
      libavdevice    60.  2.101 / 60.  2.101
      libavfilter     9.  8.102 /  9.  8.102
      libswscale      7.  3.100 /  7.  3.100
      libswresample   4. 11.100 /  4. 11.100
      libpostproc    57.  2.100 / 57.  2.100
    [NULL @ 000001d23b6d4740] non-existing PPS 0 referenced
    [h264 @ 000001d23b6d4740] non-existing PPS 0 referenced
    [h264 @ 000001d23b6d4740] decode_slice_header error
    [h264 @ 000001d23b6d4740] no frame!
        Last message repeated 1 times
    Then it starts to encode
    stream 1 : no PTS found at end of file, duration not set
    Input #0, mpegts, from 'D:\HDDEEN5020\UFC\fightpass\720p.ts':
      Duration: 02:20:55.42, start: 0.078000, bitrate: 1557 kb/s
      Program 1
      No Program
      Stream #0:0[0x50]: Video: h264 (High), yuv420p(progressive), 1280x720, 30 fps, 30 tbr, 90k tbn
      Stream #0:1[0x151]: Audio: aac (LC), 48000 Hz, stereo, fltp, 133 kb/s
    Output #0, mp4, to 'D:\HDDEEN5020\UFC\fightpass\720p.mp4':
      Metadata:
        encoder         : Lavf60.10.100
      Stream #0:0: Video: h264 (High) (avc1 / 0x31637661), yuv420p(progressive), 1280x720, q=2-31, 30 fps, 30 tbr, 90k tbn
      Stream #0:1: Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 133 kb/s
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:1 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 2334176, current: 2334144; changing to 2334177. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 2737664, current: 2737296; changing to 2737665. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 3043712, current: 3043488; changing to 3043713. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 3124880, current: 3124800; changing to 3124881. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 3345968, current: 3345792; changing to 3345969. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 4383936, current: 4383696; changing to 4383937. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 10610048, current: 10609968; changing to 10610049. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 14426672, current: 14426640; changing to 14426673. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 20892176, current: 20892144; changing to 20892177. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 21065360, current: 21065088; changing to 21065361. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 21617120, current: 21616752; changing to 21617121. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 21715088, current: 21714960; changing to 21715089. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 22656368, current: 22656240; changing to 22656369. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 36395136, current: 36394416; changing to 36395137. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 36541664, current: 36541632; changing to 36541665. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 38747120, current: 38746992; changing to 38747121. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 42295920, current: 42295584; changing to 42295921. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 54026624, current: 54026496; changing to 54026625. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 72425760, current: 72425424; changing to 72425761. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 82502000, current: 82501824; changing to 82502001. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 85062704, current: 85062576; changing to 85062705. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 85258544, current: 85258320; changing to 85258545. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 85454480, current: 85454208; changing to 85454481. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 85513104, current: 85512768; changing to 85513105. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 88114224, current: 88113840; changing to 88114225. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 99520304, current: 99520272; changing to 99520305. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 100832000, current: 100831920; changing to 100832001. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 101767136, current: 101766912; changing to 101767137. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 109960688, current: 109960608; changing to 109960689. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 110337776, current: 110337456; changing to 110337777. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 112681616, current: 112681392; changing to 112681617. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 112730960, current: 112730928; changing to 112730961. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 118106480, current: 118106304; changing to 118106481. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 118419392, current: 118419024; changing to 118419393. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 118576160, current: 118576080; changing to 118576161. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 121897328, current: 121897200; changing to 121897329. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 122389424, current: 122389344; changing to 122389425. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 123889824, current: 123889200; changing to 123889825. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 133331280, current: 133330704; changing to 133331281. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 136184192, current: 136184112; changing to 136184193. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 144936960, current: 144936816; changing to 144936961. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 145053152, current: 145052928; changing to 145053153. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 157821200, current: 157821024; changing to 157821201. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 158036112, current: 158035680; changing to 158036113. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 167175440, current: 167175312; changing to 167175441. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 184146336, current: 184145952; changing to 184146337. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 185166416, current: 185166240; changing to 185166417. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 185768624, current: 185768592; changing to 185768625. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 186026832, current: 186026208; changing to 186026833. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 186747728, current: 186747552; changing to 186747729. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 186781184, current: 186781104; changing to 186781185. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 187387088, current: 187387056; changing to 187387089. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 187770032, current: 187770000; changing to 187770033. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 188861504, current: 188861088; changing to 188861505. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 190400672, current: 190400640; changing to 190400673. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 190967360, current: 190967184; changing to 190967361. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 191065232, current: 191065152; changing to 191065233. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 207966512, current: 207966432; changing to 207966513. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 209519840, current: 209519616; changing to 209519841. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 213935168, current: 213934896; changing to 213935169. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 220082912, current: 220082640; changing to 220082913. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 220977392, current: 220977312; changing to 220977393. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 221108288, current: 221108256; changing to 221108289. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 221510720, current: 221510688; changing to 221510721. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 226177616, current: 226177584; changing to 226177617. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 226275728, current: 226275408; changing to 226275729. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 227268320, current: 227268096; changing to 227268321. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 241691504, current: 241691472; changing to 241691505. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 243863744, current: 243863472; changing to 243863745. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 248428544, current: 248428080; changing to 248428545. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 258134624, current: 258134592; changing to 258134625. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 264305808, current: 264305136; changing to 264305809. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 276178656, current: 276178080; changing to 276178657. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 278478656, current: 278478528; changing to 278478657. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 282626480, current: 282626448; changing to 282626481. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 283416320, current: 283415952; changing to 283416321. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 283449296, current: 283449216; changing to 283449297. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 284178752, current: 284178720; changing to 284178753. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 284195216, current: 284195040; changing to 284195217. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 284285264, current: 284284848; changing to 284285265. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 284888576, current: 284888352; changing to 284888577. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 285109664, current: 285109584; changing to 285109665. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 285299120, current: 285298848; changing to 285299121. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 285579104, current: 285578976; changing to 285579105. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 286003392, current: 286003104; changing to 286003393. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 287917280, current: 287917200; changing to 287917281. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 288124592, current: 288124512; changing to 288124593. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 295711184, current: 295711056; changing to 295711185. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 304916448, current: 304916160; changing to 304916449. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 304940816, current: 304940736; changing to 304940817. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 306018560, current: 306018528; changing to 306018561. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 306215184, current: 306214992; changing to 306215185. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 307861440, current: 307861200; changing to 307861441. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 309867536, current: 309867168; changing to 309867537. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 310098368, current: 310098096; changing to 310098369. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 312250928, current: 312250848; changing to 312250929. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 312611792, current: 312611760; changing to 312611793. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 314511296, current: 314511120; changing to 314511297. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 315562880, current: 315562752; changing to 315562881. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 319700448, current: 319699920; changing to 319700449. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 326975984, current: 326975856; changing to 326975985. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 328268048, current: 328267968; changing to 328268049. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 329748272, current: 329748240; changing to 329748273. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 329780672, current: 329780064; changing to 329780673. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 330150896, current: 330150576; changing to 330150897. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 336940064, current: 336939888; changing to 336940065. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 340463504, current: 340463424; changing to 340463505. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 341407952, current: 341407920; changing to 341407953. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 344534528, current: 344534448; changing to 344534529. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 344747792, current: 344747712; changing to 344747793. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 346352240, current: 346351920; changing to 346352241. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 351913776, current: 351913488; changing to 351913777. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 359150288, current: 359149968; changing to 359150289. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 361062224, current: 361062192; changing to 361062225. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 363133664, current: 363133152; changing to 363133665. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 363585440, current: 363585216; changing to 363585441. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 364932992, current: 364932912; changing to 364932993. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 366462608, current: 366462288; changing to 366462609. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 384024656, current: 384024384; changing to 384024657. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 387520928, current: 387520656; changing to 387520929. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 387537296, current: 387537264; changing to 387537297. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 388465232, current: 388464912; changing to 388465233. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 395826672, current: 395826432; changing to 395826673. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 399126416, current: 399126384; changing to 399126417. This may result in incorrect timestamps in the output file.
    [mp4 @ 000001d23c010840] Non-monotonous DTS in output stream 0:1; previous: 402966176, current: 402966144; changing to 402966177. This may result in incorrect timestamps in the output file.
    [out#0/mp4 @ 000001d23b6b7a80] video:1344206kB audio:135283kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.439333%
    frame=252193 fps=42485 q=-1.0 Lsize= 1485988kB time=02:20:55.32 bitrate=1439.7kbits/s speed=1.42e+03x
    PS C:\Users\HDDEEN5020>
    Can someone help.
  2. usually when we download ts, better first binary merge it to one .ts file, then convert it to mp4 or mkv.
  3. Try to remux it only prior to further elaborations, g.e. with mkvtoolnix.
  4. Originally Posted by ProWo View Post
    I didnt get you.
    I download the ts file it's merged as an example 720p.ts
    But when I enode it to mp4 via ffmpeg its always out of sync. below is the commad I use usually takes onlly few secnods
    ffmpeg -i D:\HDDEEN5020\720p.ts -c copy D:\HDDEEN5020\720p.mp4
  5. Originally Posted by RKO4321 View Post
    I didnt get you.
    This command isn't an encode, but a streamcopy.
    You have problems with this ts file, because it's timecodes are messed up.
    That's why i advised you to remux the ts file first.
    Start mkvtoolnix, drag & drop the ts file into the upper window and click start multiplexing (bottom center).
    Then play the new mkv file to see if everything is synchronized. If so, you can then remux this mkv file to mp4.
  6. Originally Posted by ProWo View Post
    I didnt get you.
    did that, it just givig me a 4kb file
  7. Originally Posted by LZAA View Post
    Url?
    for the video file? its a paying site. not p o r n
    Dec 2021
    england
    ufcfightpass ?
  9. Originally Posted by iamghost View Post
    ufcfightpass ?
    Yes
    Dec 2021
    england
    i check, there is no drm, have 2 m3u8 (1 for video 1 for audio) done merge together with mkvtoolnix
    sound is in sync
    [Attachment 75576 - Click to enlarge]
  11. I cant seem to get the file downloaded
    downloaded the file with IDM TS file but when I try to streancopy to mp4 file is oos
    Can you show me your guide how you did that?
    Dec 2021
    england
    for no drm you need this all together in folder
    N_m3u8DL-RE.exe
    ffmpeg.exe
    F12 inspect on your browser, filter/search for m3u8 (index) 2 of them not master(will give error)
    video
     N_m3u8DL-RE.exe "https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/audio/288e76cf-f90f-44bf-96fc-6088bb70d3bc/index.m3u8?hdntl=exp=1702909183~acl=%2f*~id=b8f49c4f-4189-4fad-adbb-a73a7391b5fb~data=hdntl~hmac=562c26d99f959ec6faa2a1f400e380703c1e0467bf038179fa9d8bb62c052bb6"
    audio
    N_m3u8DL-RE.exe "https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/bf798f01-19ea-4431-89b0-07c9c730fd30/index.m3u8?hdntl=exp=1702909183~acl=%2f*~id=b8f49c4f-4189-4fad-adbb-a73a7391b5fb~data=hdntl~hmac=562c26d99f959ec6faa2a1f400e380703c1e0467bf038179fa9d8bb62c052bb6"
    use mkvtoolnix or ffmpeg to merge both into 1
  13. Thank you so much I got the video file
    2 question how to identify the video resolutio throuh that link
    and I cant seem to find thee audio ;ink by your method
    Dec 2021
    england
    this?
    [Attachment 75582 - Click to enlarge]
    if so, it master.m3u8 can not copy link paste on cmd with N_m3u8DL-RE, it will get error. and can not download m3u8 file. so only way is you must hightligh/copy from f12 preview tab paste it on notepad. and add "https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/" in every link url in m3u8 like that...
    #EXTM3U
    #EXT-X-INDEPENDENT-SEGMENTS
    #EXT-X-MEDIA:TYPE=AUDIO,URI="https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/audio/288e76cf-f90f-44bf-96fc-6088bb70d3bc/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815",GROUP-ID="audio-3",LANGUAGE="eng",NAME="English",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2"
    #EXT-X-MEDIA:TYPE=AUDIO,URI="https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/audio/fbf2f3dc-396b-4f5f-bebd-d91290911824/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815",GROUP-ID="audio-1",LANGUAGE="eng",NAME="English",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2"
    #EXT-X-MEDIA:TYPE=AUDIO,URI="https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/audio/9997bbba-459d-4ce6-9136-ee68cada0933/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815",GROUP-ID="audio-2",LANGUAGE="eng",NAME="English",AUTOSELECT=YES,DEFAULT=YES,CHANNELS="2"
    #EXT-X-STREAM-INF:BANDWIDTH=4372267,AVERAGE-BANDWIDTH=3588734,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.640029,mp4a.40.2",RESOLUTION=1280x720,AUDIO="audio-2"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/a00b0c0d-df56-4349-acad-c19d590f2ed2/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=10081749,AVERAGE-BANDWIDTH=8155243,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.64002a,mp4a.40.2",RESOLUTION=1920x1080,AUDIO="audio-3"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/bf798f01-19ea-4431-89b0-07c9c730fd30/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=6350528,AVERAGE-BANDWIDTH=5115288,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.640029,mp4a.40.2",RESOLUTION=1920x1080,AUDIO="audio-2"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=2108747,AVERAGE-BANDWIDTH=1698840,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.640029,mp4a.40.2",RESOLUTION=1280x720,AUDIO="audio-2"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/0768c3a8-3d92-4e45-b43c-e73802b78740/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=1419664,AVERAGE-BANDWIDTH=1149662,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.4d4028,mp4a.40.2",RESOLUTION=896x504,AUDIO="audio-2"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/4aebe46c-0d30-4313-b159-82953f24d4dc/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=941142,AVERAGE-BANDWIDTH=772203,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.42c01f,mp4a.40.2",RESOLUTION=640x360,AUDIO="audio-2"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/5b0deb7a-9db2-4cb7-9824-6989a514403f/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    #EXT-X-STREAM-INF:BANDWIDTH=544057,AVERAGE-BANDWIDTH=452099,FRAME-RATE=30,PROGRAM-ID=1,CODECS="avc1.42c01f,mp4a.40.2",RESOLUTION=512x288,AUDIO="audio-1"
    https://dve-streams.akamaized.net/ns-005/MjAyMg/Nw/M_TE/f2da101f-e3f4-4c5c-b790-4ca32020c45d/video/c85a7ca0-d29a-4745-ac8f-0db23e3b4674/index.m3u8?hdntl=exp=1702914798~acl=%2f*~id=e952b902-9d25-4719-9902-5f5552202dc9~data=hdntl~hmac=fc587eb1c9117ac98efe4d3564a03a321e2110ac60e81043fcc10251da308815
    use cmd: N_m3u8DL-RE.exe "PATH where is m3u8.txt save"
    [Attachment 75583 - Click to enlarge]
  15. Thank you so much, I got it now.
    can you help me with saved path command too? -c copy "D:\F\fs\test.mp4" doesnt work.
    its always download to C drive
