Hi, I have a few old series downloaded from streaming platforms.
The quality, let's say, OK, but...
The resolution is not good, they cut part of the original video and made it 16:9, but it is not.
It is also not 4:3, so I have no editor to let me put a custom resolution.
The downloaded videos are 1920x1080, with black areas on both sides of the video.
Besides the video is a little bit extended.
So, I want:
1. Cut these black areas (actually I can do it with UniConverter).
2. Adjust the color gamma slightly (also can do it with UniConverter).
3. After I cut the black areas, the final video is a little bit extended - 1610x1080, but it must be 1545x1080.
I have MKV and MP4 video files.
What would you recommend me to use to not lose the video quality?
PS: Avidemux makes crop better, with almost the same video quality as the original file, but it takes more time than a crop with UniConverter. Besides, UniConverter allows adding all 155 episodes in just 1 click, then setting the desired crop size (brightness, etc) and applying it to all files, and then going to sleep and getting all 155 episodes edited in the morning. But the video quality will be a little bit lower.
Later, with Avidemux to correct the width of the video, it takes 10 seconds per episode.
Making all with Avidemux is a much better final quality of the video, almost the same as was the original file, but it takes 30-45 min per episode.
[VSDC Video Editor] Transforms do not work correctly when exporting video.
By shibata33 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2024, 14:47 -
What video editor would you recommend for this purpose?
By Astralogic in forum LinuxReplies: 2Last Post: 7th Dec 2021, 18:07 -
Can someone recommend a video editing software?
By miogpsrocks in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2020, 13:31 -
VSDC Free Video Editor - Secondo video in trasparenza sul primo
By OTMAN in forum Newbie / General discussionsReplies: 0Last Post: 6th Mar 2019, 07:56 -
Can you recommend an external video stabilizer?
By digicube in forum Capturing and VCRReplies: 12Last Post: 18th Dec 2018, 23:21
