Do any NLE programs have a max file size when importing to edit? FAT32 is 4GB and NTFS is massively big, but what editing programs have file size limits on videos they read in for editing?
Do people split long videos to keep a recommended maximum file size for compatibility with editors? I'm bringing in mDV and Hi8 tapes. winDV sets a 22500 frame / 12.5min NTSC or 15min PAL by default.... but what do most people use for max limit?
	Not sure why you needed to start a new thread, when this is picking up from the other one...
 Most major commercial NLEs (not counting freeware here) support whatever the Filesystem & Fileformat specs say are the limit.
 I know I've used AdobePremiere, Vegas Pro (older, Sony version), AVID MediaComposer, and Davinci Resolve and have never had file limitation issues. And I've captured hours-long footage, in both DV, and intermediate codecs (ProRes, DNXHD, Cineform) and Lossless (HUFFYUV and Lagarith), so those file sizes are in the multi- or hundred- Gigabyte range.
 With freeware/OpenSource stuff, YMMV, but I would expect there to be few issues. And IMO, if it can't handle it, it probably isn't well written.
	No, not the good ones.Do any NLE programs have a max file size when importing to edit?
 Don't use FAT32;you'll get stopped at the 4GB limit. Use NTFS for your HD drives. You might be stuck with FAT 32 for thumbdrives and some playing devices, but you won't be capturing/editing on those.
 No. There is no limit. I regularly capture 3hr VHS tapes into lossless format, resulting in an AVI file of ~80GB. No problem editing that.Do people split long videos to keep a recommended maximum file size for compatibility with editors?
 Set it on 999999 (unless you want to limit your capture length when, say, you're using a DV camcorder to do an analogue to digital capture where the camcorder/ADVC is just being used for passthrough and doesn't actually have a tape running in it).I'm bringing in mDV and Hi8 tapes. winDV sets a 22500 frame / 12.5min NTSC or 15min PAL by default.... but what do most people use for max limit?Last edited by Alwyn; 14th Dec 2023 at 19:30. Reason: "Unless..." added.
	Hi, thank you for your explanation it helps me too.
  WinDV skips frames after reaching Max AVI size?By cbracer in forum Capturing and VCRReplies: 5Last Post: 14th Dec 2023, 12:44
  How to best care for my new computer + recommended USB adapter?By Jeikobu in forum MacReplies: 1Last Post: 11th Sep 2021, 13:49
  Recommended Video Editing LaptopBy Alphantom in forum ComputerReplies: 4Last Post: 28th Jan 2021, 12:24
  What is recommended for a good 8mm camcorder for capturing video?By jadoggin in forum Capturing and VCRReplies: 8Last Post: 7th Nov 2019, 13:23
  Recommended S-Video Card for BetaSP?By Crydajam in forum Capturing and VCRReplies: 3Last Post: 4th May 2019, 23:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
