Hello,
I converted a .mkv video of 1.26Gb to .mp4 using HandBrake with the default profile "Fast 1080p30" as I wanted to keep the same aspect ratio.
I removed two language tracks and all the subtitles (I've impressed the forced one during conversion) as I don't need them, with the idea to make the file smaller.
The result is a video of 1.56Gb. I can't see what could have increased the size.
Source:
[Attachment 75529 - Click to enlarge]
Result:
[Attachment 75530 - Click to enlarge]
Thank you
First of all:
To convert your video from mkv to mp4, it was not necessary to re-encode it. A simple remux would have been sufficient and you could have left out the superfluous streams (audio, subtitles). This would have been very quick and, above all, would not have resulted in any loss of quality.
Regarding your question about the video size:
if you want a smaller size you have to reduce the bitrate.
In addition, you have changed from a better compression (hevc) to a worse one (x264/avc). -
You could have simply remuxed the original MKV file in MKVToolNix and uticked the tracks you didn't need. Click on remux and 4 minutes later all done. No loss of quality, a tad smaller...
Changing/removing language informatio of tracks in TS file without remuxing
By DarkyOne in forum Blu-ray RippingReplies: 1Last Post: 8th Feb 2022, 01:33 -
By DarkyOne in forum EditingReplies: 1Last Post: 8th Feb 2022, 01:31 -
Split video and audio tracks in seperate files from a MKV source file
By ElegantRain in forum Video ConversionReplies: 29Last Post: 13th Sep 2021, 12:28 -
removing subtitles and audio tracks from mkv
By thaynos in forum SubtitleReplies: 10Last Post: 5th Sep 2021, 10:03 -
Removing subtitle tracks from video files?
By Sephiroth666 in forum EditingReplies: 20Last Post: 20th Jun 2021, 17:56
