Hey
It used to work with kodi but foxtel plugin no longer works with kodi so wondered if anyone knows how to get HD mpd instead of just medium?
Theres a setting to enable in account, where you change it from low to auto or auto to high or something like that, which will give you the HD mpd.
Hey Pauli3. I did try that and still no luck. Although they do seem to play in 1080, the manifest only ever shows medium and the highest quality within that manifest is 576 even though I refreshed many times and tried many videos.
The only method which ever enabled me to find the HD MPD was going through Kodi logs using the foxtel go plugin but kodi foxtelgo plugin no longer works either unfortunately.. -
Foxtel is known to protect/monitor their content, no idea why since its not that great, but its likely your account got flagged and is set to get the lower quality manifests. One further way which has worked in the past, using a smart-tv device eg. amazon firetv, and mitm/intercept the high manifest from there.
Hey Pauli
If I were to use an amazon firestick to get the HD MPD, Would this be done via the foxtelgo app? Then would there be a file it creates which I can only access if the device was rooted? If so do you know the location of the file?
Appreciate you getting back -
The medium playlist gets served with Foxtel Go
Code:https://foxteldashvod01.akamaized.net/store2/ON815986/ON815986_mcs.ism/playlist_medium.mpd?.....
Code:https://foxteldashvod01.akamaized.net/store2/ON815986/ON815986_mcs.ism/playlist_high.mpd?.....
Anyway this is all a moot point. Discussion around pay sites is against the forum rules, so I expect this thread to be locked.
Download encrypted video via DRM protected MPD manifest
By Beta2k in forum Video Streaming DownloadingReplies: 19Last Post: 15th Jan 2024, 10:47 -
Need help downloading a DRM .mpd manifest
By fuzzco in forum Video Streaming DownloadingReplies: 4Last Post: 25th Mar 2022, 22:08 -
Help downloading .mpd dash stream with no manifest
By JustPassing in forum Video Streaming DownloadingReplies: 9Last Post: 19th Nov 2021, 05:51 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
Help downloading manifest mpd
By therain in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Nov 2020, 13:26
