Hello folks,
with the help of some research I came across The Stream Detector.
And tried to download something from joyn.at.
I used N_m3u8DL-RE for this.
At the first attempt I forgot the audio track and the picture just stayed black.
So I kept searching and came across this page.Code:N_m3u8DL-RE_Beta_win-x64_20230628>N_m3u8DL-RE "https://delivery.vod-prd.s.joyn.de/v1/CiRjMDM2ZWUzNy0wODdhLTQ5NjAtYWIyNy0yNTkxMWQ1M2NiMzM.Cg1hX3BmNGZtZ2MzcjNtEAQY4AMiJGJhNGIwYTE2LWM0ZmMtNDA2MC1hMTAyLWFlMjE1Njk5ZGZlYQ.asvPIWGqxAXZkd-mX2x1ptXwY9mHuneP21X9LU1yJCc/a_pf4fmgc3r3m/.ism/.mpd?filter=CiRkMmRiNzQ5OS02MmU0LTQ0MjYtODRiZS1mYzA1NDBhYTA4NDY.Cg1hX3BmNGZtZ2MzcjNtElYodHlwZT09InZpZGVvIiYmTWF4SGVpZ2h0PD00ODApfHwodHlwZT09ImF1ZGlvIiYmRm91ckNDPT0iQUFDTCIpfHwodHlwZT09InRleHRzdHJlYW0iKQ.nGeogCnjcK0pho3keaM2LXnprJjdBYiIK73LQewqW-c" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:108.0) Gecko/20100101 Firefox/108.0" --header "Referer: https://www.joyn.at/" --save-name "HotD-S1E1"
So I added shaka and also some parameters.
Now I have a picture, but apparently a decoding error.Code:N_m3u8DL-RE_Beta_win-x64_20230628>N_m3u8DL-RE "https://delivery.vod-prd.s.joyn.de/v1/CiRjMDM2ZWUzNy0wODdhLTQ5NjAtYWIyNy0yNTkxMWQ1M2NiMzM.Cg1hX3BmNGZtZ2MzcjNtEAQY4AMiJGJhNGIwYTE2LWM0ZmMtNDA2MC1hMTAyLWFlMjE1Njk5ZGZlYQ.asvPIWGqxAXZkd-mX2x1ptXwY9mHuneP21X9LU1yJCc/a_pf4fmgc3r3m/.ism/.mpd?filter=CiRkMmRiNzQ5OS02MmU0LTQ0MjYtODRiZS1mYzA1NDBhYTA4NDY.Cg1hX3BmNGZtZ2MzcjNtElYodHlwZT09InZpZGVvIiYmTWF4SGVpZ2h0PD00ODApfHwodHlwZT09ImF1ZGlvIiYmRm91ckNDPT0iQUFDTCIpfHwodHlwZT09InRleHRzdHJlYW0iKQ.nGeogCnjcK0pho3keaM2LXnprJjdBYiIK73LQewqW-c" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:108.0) Gecko/20100101 Firefox/108.0" --header "Referer: https://www.joyn.at/" --save-name "HotD-S1E1" --use-shaka-packager -M mp4
I hope someone can help, because the stream is only possible until about 28.12.
Thank you!
Greetz mcdy
Results 1 to 14 of 14
Hello Obo,
thanks for response.
Shouldn't the Software read the decryption keys automatically?
Anyway this is the URL: https://www.joyn.at/play/serien/house-of-the-dragon/1-1-die-erben-des-drachenOriginally Posted by LOG
Thanks!
Greetz mcdy -
No, not that I know of. That would be too easy, wouldn't it?
That series isn't available from joyn.de, and I don't use a VPN here, so I can't get the keys for you.
(But joyn.de is very easy to get the keys from, the process for joyn.at is probably the same.) -
Hello Obo,
not that easy but it works.
Used https://cdrm-project.com/ to do so.
Now I tried to decrypt already downloaded file with shaka.
And get this log and still an unsable file.Code:packager-win-x64 input=HotD-S1E1.mp4,stream=video,output=HotD-S1E1_decrypt.mp4 --enable_raw_key_decryption --keys key_id=5e2c4755a0b64dbe845c2497fad51d26:key=98391060e3ac8398e0ab37786199075f --keys key_id=af8ed1f03f265ad19eef25850d981de4:key=1ff4db8250e715299939e27993672f0d --keys key_id=b651ce6b6ce6518aa60b669c3725e6a9:key=4da52e1c64b7317b4ee963ca9ab828d1 --keys key_id=80cb81d166fc5d2d990988803898591f:key=439ddc27c48b84316b359d37f25ed207
Any ideas?Originally Posted by log
Thanks!
Greetz mcdy -
Never used that application. I usually use mp4decrypt. That application needs the keys in the format --key <id>:<k>
N_m3u8DL-RE -M format=mkv --key 5e2c4755a0b64dbe845c2497fad51d26:98391060e3ac8398e0ab37786199075f --key af8ed1f03f265ad19eef25850d981de4:1ff4db8250e715299939e27993672f0d --key b651ce6b6ce6518aa60b669c3725e6a9:4da52e1c64b7317b4ee963ca9ab828d1 --key 80cb81d166fc5d2d990988803898591f:439ddc27c48b84316b359d37f25ed207 "https://delivery.vod-prd.s.joyn.de/v1/CiRjMDM2ZWUzNy0wODdhLTQ5NjAtYWIyNy0yNTkxMWQ1M2NiMzM.Cg1hX3BmNGZtZ2MzcjNtEAQY4AMiJGJhNGIwYTE2LWM0ZmMtNDA2MC1hMTAyLWFlMjE1Njk5ZGZlYQ.asvPIWGqxAXZkd-mX2x1ptXwY9mHuneP21X9LU1yJCc/a_pf4fmgc3r3m/.ism/.mpd?filter=CiRkMmRiNzQ5OS02MmU0LTQ0MjYtODRiZS1mYzA1NDBhYTA4NDY.Cg1hX3BmNGZtZ2MzcjNtElYodHlwZT09InZpZGVvIiYmTWF4SGVpZ2h0PD00ODApfHwodHlwZT09ImF1ZGlvIiYmRm91ckNDPT0iQUFDTCIpfHwodHlwZT09InRleHRzdHJlYW0iKQ.nGeogCnjcK0pho3keaM2LXnprJjdBYiIK73LQewqW-c" --save-name video
[Attachment 75528 - Click to enlarge] -
Hey Obo,
I downloaded it again but will try it next time with mp4decrypt - thx
Hey iamghost,
thanks I now download E1 and E2 like this:
When I try to download E3, it is encrypted.Code:N_m3u8DL-RE "https://joyn-vod-prd.akamaized.net/v1/CiRjMDM2ZWUzNy0wODdhLTQ5NjAtYWIyNy0yNTkxMWQ1M2NiMzM.Cg1hX3BmNGZtZ2MzcjNtEAQY4AMiJGJhNGIwYTE2LWM0ZmMtNDA2MC1hMTAyLWFlMjE1Njk5ZGZlYQ.asvPIWGqxAXZkd-mX2x1ptXwY9mHuneP21X9LU1yJCc/a_pf4fmgc3r3m/.ism/.mpd?filter=CiRkMmRiNzQ5OS02MmU0LTQ0MjYtODRiZS1mYzA1NDBhYTA4NDY.Cg1hX3BmNGZtZ2MzcjNtElYodHlwZT09InZpZGVvIiYmTWF4SGVpZ2h0PD00ODApfHwodHlwZT09ImF1ZGlvIiYmRm91ckNDPT0iQUFDTCIpfHwodHlwZT09InRleHRzdHJlYW0iKQ.nGeogCnjcK0pho3keaM2LXnprJjdBYiIK73LQewqW-c" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36" --header "Referer: https://www.joyn.at/" --save-name "House of the Dragon Staffel 1 Folge 1" --key-text-file "House of the Dragon Staffel 1 Folge 1.txt" --use-shaka-packager -M mkv
I recognized that the keys are the same as on E2, could that be?
Or is that a fail by https://cdrm-project.com/
Thanks!
Greetz mcdy -
Try again f12 then press f5 for refresh page to get right pssh and license
You can always use your own cdm to extract the keys; I've posted a simple initial script here: https://forum.videohelp.com/threads/412209-Download-from-plus-rtl-de/page2#post2712294, you only need your license url and pssh or mpd url
look inside E3 mpd, find KID.
does it match any below
d52029ae07d3ec625aac15ae310ce0c4
652f6771c7145efd8d208943e4b5c587
782d2743ff605478aab44f52289f2194
949f1a2a806057e5bd0fc596f28db28c -
How do I download these? I have N_m3u8DL-RE but it doesn't work.
https://www.joyn.at/serien/atv-die-reportage/192-1-atv-die-reportage-nackerpatzerl-auf-reisen
https://www.joyn.at/serien/atv-die-reportage/27-4-atv-die-reportage-freikoerperkultur
https://www.joyn.at/serien/atv-die-reportage/79-2-atv-die-reportage-nacktes-oesterreich
Video Download from Joyn.de
By Data2006 in forum Video Streaming DownloadingReplies: 145Last Post: 20th Sep 2025, 14:09 -
How can i decrypt a stream from Joyn?
By PyNoob in forum Video Streaming DownloadingReplies: 7Last Post: 29th Jan 2025, 04:48 -
A GUI to download bulk download files through their respective M3U8 links
By UNforces885 in forum Video Streaming DownloadingReplies: 4Last Post: 4th May 2023, 14:04 -
Download HLS. error 400 to download keys
By naturalc in forum Video Streaming DownloadingReplies: 28Last Post: 28th Oct 2022, 08:13 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 21:28
ingle_segment_segmenter.cc(111)] Update media header (moov) and rewrite the file to 'HotD-S1E1_decrypt.mp4'.
