I've got WinDVD3.0 installed on my Win2kpro computer, and its started doing something quite weird recently. I establish a playlist with the files I wish to view on a SVCD, and after it reaches the end of the 1st file in the playlist, it completely shuts down and exits, and doesn't go onto the next file. I was wondering if anybody else had had this problem, and if so, how one would go about fixing it. Thanks.
Try WinDVD 4.0 Plus version. It is so cool.
Features
PAL TrueSpeed
Time-Stretching
Video
MEPG-1/MPEG-2 Decoder
Full Range Color Adjustment Partial
Full TV color adjustments
Display Gamma Correction
Hardware Video Accerleration
Pan & Scan Option
Advanced De-interlacing
Audio
DTS Digital Surround
Dolby Digital Decoder
Dolby EX
Dolby Pro Logic II
SRS TruSurround XT
Dolby Headphone Technology
Multi-Channel Mp3 Playback
LFE Mixer
Environment (Dynamic Range Compression)
InterVideo Channel Expansion
DSP Audio Effects
Pitch Shift and Vocal Suppression
User Controls and Features
DVD default preference setting
Instant Replay and Skip Forward
Customizable Screen Capture
Skin Options
Auto-Resume Playback
Thumbnail Bookmark
Chapter Thumbnail
Integrated DVD/VCD Menu
A/B Repeat
Video on Desktop
Video Always on Top
Forward/Backward Step
Multi-User Parental Control
Device Support
TV Ouput Support -
PowerDVD is better. I suggest trying that, but if your problem persists, it has to be more serious than the program you are using.
Visit my webpage at:
http://leech.at/e-z-e -
windvd 4 kicks powerdvd out the door in features and stability it has heaps more features
Nice double post. PowerDVD is better simply because it is less buggy. I strongly suggest PowerDVD over WinDVD. Just my opinion though.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
