Very frustrated with all these errors and having to try to explain them.
I reinstalled Subtitle Edit from videohelp- v. 4.01 that I had on before.
My target MKV now has no sound. The peculiar thing is the file starts up at O volume repeatedly so I had
to be reset each time. Setting the volume to max did not help.
I loaded a different MKV and the volume worked ok.
So I mounted my backup HD which (since not changed) plays ok and does not require resetting each time.
I don't know where to start on such a thing. I have a working system, I need to fix what is now a non-working backup.
I've never had an audio problem in SE before.
	Solved.
 https://forum.videohelp.com/threads/409792-Subtitle-Edit-No-sound-in-video
 This thread above gave a hint as to what took my sound off after reinstall.
 I had Direct Show set rather than the button for MPV at screen top during the reinstall process. I thought I had verified all that but....
 But I still don't know how Direct Show functions as an engine in Subtitle Edit, or how to install NLC or MPC-HT.
  Reinstalling video player in Subtitle EditBy loninappleton in forum SubtitleReplies: 10Last Post: 30th Dec 2023, 00:28
  Subtitle Edit - No sound in videoBy pboite in forum SubtitleReplies: 10Last Post: 20th Dec 2023, 01:58
  Subtile numbering not in chronological orderBy loninappleton in forum SubtitleReplies: 18Last Post: 14th Jul 2022, 01:28
  CED Player can you remove sound with magnet?By anonymoustly in forum MediaReplies: 2Last Post: 13th Feb 2022, 17:13
  No display nor sound while playing the VHS playerBy TommyL in forum RestorationReplies: 17Last Post: 11th Mar 2021, 12:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
