when I want to move the slider across to a part of the video, its like its controlled in set chapters, although very short. I dont know what setting do I need to adjust
and when I want to advance the movie forward or back 2 seconds, I think it does 5 seconds or so. any way to configure for less time?
thank you in advance.
thanks so much. I didnt even get to the bottom there are so many options. I was certain it was in playback area. cheers!
mpc-hc: (O)ptions>Player>Keys:enter jump
There was a suggestion to rename these options to jump/seek. -
You have to define your own keys.
Options/Keys
The most common shortcuts are already defined.
Clear the key cell (double click on the key cell/right click/clear) for the shortcuts you wish to redefine elsewhere.
I find it a bit of a mess and have settled for just the one jump distance. 5000ms
For shorter jumps I use 'Frame-step'. Ctrl+Right arrow
For longer jumps I use the slider.Last edited by pcspeak; 14th Dec 2023 at 11:31.
Weird time skip issue during capturing vhs tapes
By Fixir in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2022, 05:44 -
Skip to next file in playlist at time stamp
By Yanta in forum Software PlayingReplies: 0Last Post: 22nd Aug 2022, 08:58 -
can't randomly skip ahead in ripped ntflx videos
By tripnikk in forum Video Streaming DownloadingReplies: 2Last Post: 9th Sep 2021, 22:38 -
possible to tell MPC-HC to always skip the last 30 seconds of a video?
By Gwar in forum Software PlayingReplies: 5Last Post: 12th Nov 2020, 06:36 -
MPC-HC How to Skip non audio files?
By mpcfun in forum Software PlayingReplies: 1Last Post: 1st Oct 2020, 02:48
