I started checking my SCART-SCART cables. The Toshiba VCR (JVC, too) gives a nice blue control image, so all anomalies can be clearly seen.
I didn't limit myself to one-way test transmission -- I sent the TV signal (movie) from the TV to the VCR, and the blue control screen in the other direction (via the same cable).
As a result, it turned out that only on one cable I had a perfect blue picture, on all the others there was a "shadow" (I don't know the correct word) of the TV signal.
The perfect cable is 10mm in diameter, the remaining ones are 6-6.5mm - what a coincidence![]()
External diameter doesn't mean anything nowadays - frequently "thick" are internally very poor quality - open SCART connector and inspect what is inside - search for coaxial cables - if there is no coaxial cable (on component and composite signals) then probably overall cable quality is poor.
VGA cables can be thicker or not but they provide a least 100..150MHz bandwidth.
SCART to S-Video adapter strange problems
By bigbadben in forum Newbie / General discussionsReplies: 13Last Post: 11th Dec 2023, 10:40 -
HDMI to S-Video cable or SCART to S-Video cable.Which is better for elgato?
By VideoFanatic in forum Capturing and VCRReplies: 22Last Post: 23rd Jan 2023, 14:40 -
Panasonic S-VHS NV-FS200 no signal video from scart
By Nicola71 in forum RestorationReplies: 15Last Post: 5th May 2021, 19:09 -
Looking for Cheap Capture Device for SCART Standard Definition
By AndersonJames in forum Capturing and VCRReplies: 17Last Post: 12th Sep 2020, 18:32 -
RGB Output Through SCART
By nman971 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jul 2019, 04:34
