I would say about 5. Years ago I got my DVDs of old T.V. Shows like The Land Of The Lost and Buck Rogers and so on and used MakeMKV to Copy them to my Hard Drive.
I watched them off and on with VLC Media Player.
Yes all of the .MKV Files have the VLC Media Player Icon .
I just went to Click on some of them and they Start to open then they Close.
I get no Error or anything does anybody know what is going on?
Play them in a different media player to check. Install MPC-HC (from this site) if you don't have it and then try to play them. Maybe you need to update VLC. Also using MediaInfo check the file to see if it recognises it.
That's only because you have set VLC as the system default player - means nothing. If you changed the default player to MPC for example they would all have it's icon. and so on....Yes all of the .MKV Files have the VLC Media Player Icon .SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
MakeMKV
By biferi in forum Video ConversionReplies: 64Last Post: 6th Jan 2025, 21:07 -
MakeMKV alternative?
By Instant Martian in forum DVD RippingReplies: 10Last Post: 26th Aug 2022, 10:05 -
MakeMKV
By jarod1005 in forum Newbie / General discussionsReplies: 25Last Post: 8th Feb 2022, 11:26 -
MakeMKV v1.16.4 - freezing ?
By Frasier in forum DVD RippingReplies: 2Last Post: 17th Jul 2021, 13:38 -
MakeMKV alternative - Mac?
By joshcali2 in forum MacReplies: 2Last Post: 1st Jul 2020, 22:30
